Temperature Sensor G62 & Brake Pressure Sensor G201
vlagik
Post22-05-2007, 17:41    Subject: Temperature Sensor G62 & Brake Pressure Sensor G201 Quote
"Mostly during the summer, I experience two recurring errors intermittently:"
Error No. 17664 - Intermittent short circuit.
The engine is idling too high, or the RPMs are reaching up to 2000 at idle.
Irregularly, when the coolant temperature reaches around 60 degrees.
So, it's not when the engine is cold, or even when it's normally warm (85°).
Ich habe durch VAG die Temepratur kontroliert (kalter Motor, MWB für Temperatur) und alles war i.O. Dann auch später, wenn alles wärmer war. Nirather unremarkable.
Is the donor unit G62 really broken? I searched the forum but found nothing, especially regarding this sporadic error.
Error code 01435: Implausible signal from the brake pressure sensor (G201).
The error occasionally occurs, especially when I start the car and simultaneously press the brake pedal.
I also checked the sensor through the VAG diagnostic tool (STG) in the brake electronics, and everything was fine.
Does anyone know anything about that?
Thank you everyone.
VW Golf IV Variant Edition AJM, 213 Tkm
Translated on 27-10-2026, 0:32.
tdi pumpe düse
Post22-05-2007, 18:34    Subject: Temperature Sensor G62 & Brake Pressure Sensor G201 Quote
'I also had to replace the coolant temperature sensor in my car. It was the same error and symptoms. It's a known issue that these sensors fail. I checked it, and at a certain point, it showed implausible resistance values.'
I need to check out that pressure brake sensor you mentioned; I remember something about it.
Translated on 27-10-2026, 0:34.
vlagik
Post22-05-2007, 19:12    Subject: Temperature Sensor G62 & Brake Pressure Sensor G201 Quote
Thank you for the response.
Is it true that... So, the error only occurs within a certain area, but it happens regularly.
I could try using the brake pressure sensor to control the brake light switch, as I have described in several posts.
No new posts Zero-tolerance for deviations in the steering angle of th... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Zero offset for accelerator pedal angle sensor (G85) in B... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Brake Pressure Sensor G201: Fault 01435-008 On-Board Diagnostics (OBD)
No new posts Temperature Sensor Values: How to Read & Use Diesel Engine Technology
No new posts Temperature Sensor Replacement Diesel Engine Technology
No new posts Temperature Sensor G62 Malfunction Diesel Engine Technology
