Polo 1.4l 59kW TDI DPF Blue Motion - Ist das was? | Posts 32+
Go to page: Previous  1, 2, 3
Aliendrummer
Karma: +6 / -2   Thank you, like it!
Post18-10-2006, 15:16    Subject: Quote
Just a quick question:
Why does VW only offer the "smaller" diesel engines with 3 cylinders?
Are there any advantages to that?
Is it better to have 3 large cylinders instead of 4 small ones?
Translated on 24-09-2026, 17:45.
Audi A4
Karma: +2 / -4   Thank you, like it!
Post18-10-2006, 15:38    Subject: Quote
With cylinders that are too small, the efficiency suffers because too much heat is dissipated through the "cold" cylinder walls.
Günther
Translated on 24-09-2026, 17:46.
Avatar-Jan6K
Post18-10-2006, 16:55    Subject: Quote
Martin wrote:
I consider the information about the VTG loader as not yet confirmed.
@Bavarian:
How about this? Have you checked if yours has a VTG loader?
Jan.
1Z5 CFHF / AHB H4D
Translated on 24-09-2026, 17:47.
bafische
Karma: +22 / -0   Thank you, like it!
Post18-10-2006, 18:28    Subject: Quote
dieselmartin wrote:
Compression ratio 18.5:1, 195Nm of torque from 1800-2200 RPM - all the information online is incorrect.
Why is it wrong? VW actually says exactly this - even on the internet.
"@Dieselmartin - the "wrong" information referred to the compression ratio. According to the VW website, it's 19.5:1, but the actual value is 18.5:1. I just wanted to reiterate the torque figure because there seemed to be some confusion about that as well. I probably phrased things poorly."
jochen_145 wrote:
I doubt that it will remain an "Extrawurst," as that would be far too expensive.
I expect that this engine will be available in the next Polo.
That makes sense.
@ Jochen_145 - I wouldn't be so sure about that, because first of all, they wouldn't have a Polo anymore that they could label as "BlueMotion," since 80% of the fuel efficiency comes from the engine. Secondly, it would be too expensive and unprofitable to equip all TDI Polos with a VTG turbocharger - it will remain a special feature.
jochen_145 wrote:
According to theory (or at least, according to VW's consumption diagram), the Lupo 3l should consume less than 6 liters per 100km at 160km/h. However, I haven't tested that myself. It couldn't quite reach 170km/h.
@ Jochen_145 - that's exactly why I specifically mentioned the consumption at 170 km/h, because I didn't want to compare it to the 3L Lupo - it's a completely different concept with a different target audience. icon_cool.gif
Jan6K wrote:
What about this? Have you checked on yours to see if it has a VTG loader?
@ Jan6K - Sonnenbrille abnehmen und meinen vorigen Beitrag lesen. icon_wink.gif Ja, der BlueMotion hat den hochgesetzten, um 180° gedrehten VTG-ATL von BBGW mit pneu. Control.
zum Thema warum 3-Zyl. TDI:
In my opinion, the claims about efficiency and individual cylinder chambers are a bit of a stretch.
There are 3 reasons. Cost, cost, cost.
The combustion process can be directly adopted from the 1.9L 4-cylinder TDI engine, as can almost all auxiliary components. The 3-cylinder engine is essentially a shortened version of a 4-cylinder. This is an example of a modular design system. See also the AUDI V6/V8/V12 TDI engines.
Greetings.
"Luft und Menge müssen stimmen - der Rest ist Physik."
unumstössliches Gesetz in der Dieselmotorenentwicklung
Translated on 24-09-2026, 17:50.
Post18-10-2006, 18:44    Subject: Quote
The frictional power increases with the number of cylinders.
Translated on 24-09-2026, 17:52.
Post19-10-2006, 9:33    Subject: Quote
If it's really true that the "BM" model has a VTG (variable torque geometry) while the standard model only has 80 horsepower, then the whole thing is just fat marketing and nothing else.
If I take all the 1.9 and 2.0 TDI engines and either deliberately make them run poorly (for cost reasons) or simply drill a hole in the fuel tank, I can create an "eco-TDI" that is primitively state-of-the-art (with a VTG but without an oil cooler in the tank), and it will outperform other engines AND consume less fuel.
I believe the Blue Motion is a standard 3-cylinder TDI engine, and the others (with a wastegate), as the name "waste" suggests, should be scrapped. At the very least, they should stop selling such designs.
who "suffers" from a turbocharger with a wastegate and has already experienced AMF (and suffered even more) icon_smile.gif.
Translated on 24-09-2026, 17:53.
pschaefer
Post19-10-2006, 9:37    Subject: Quote
@dieselmartinViewing profile: dieselmartin: Hey, the ALL-CAPS are back! *Keep it up!*
Translated on 24-09-2026, 17:55.
Avatar-Jan6K
Post19-10-2006, 17:32    Subject: Quote
Jan6K - Take off your sunglasses and read my previous post.
Sorry! I had already read that.
Sincerely,
Jan.
1Z5 CFHF / AHB H4D
vagtuning
Post03-06-2007, 12:08    Subject: Quote
Okay, I can't say anything bad about the BM at all.
According to the speedometer, it was about a needle's width ahead of 200 km/h, but after the FIS (reset), it showed 194 km/h. Despite driving the car for approximately 400 km mostly above 160 km/h whenever possible, I achieved a fuel consumption of 5.2 liters per 100 kilometers after refueling.
'The first trip averaged 4.8/4.9 liters per 100 kilometers (I usually drove at around 160/170 km/h with the accelerator pedal pressed about three-quarters down). On the return trip, the onboard computer indicated a consumption of 5.4/5.5 liters per 100 kilometers, showing values from the underbody to the road surface. Both times, I filled up at the same gas station (the distance to the highway entrance is about 800 meters).'
At least 438 km driven with a fuel consumption of 23.10 liters.
A bit rough in the lower gears, but overall, a very economical car (which becomes quite noisy above 160/170 km/h).
'Initial test with a very light foot didn't go exactly as expected - the lowest consumption recorded by the onboard computer was 3.9 liters per 100km over about 25km of highway. However, I think with a more aggressive driving style and a flat road, there's definitely room for improvement. Still, even with a 'heavy' foot, you can achieve the stated consumption (at a speed of approximately 95 km/h).'
Translated on 24-09-2026, 17:57.
No new posts Documented clutch failures in 4-Motion TDI-PD engines Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 4 Motion, Year 2013, Problems with ASR/ESP/ABS/Autohold Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Polo combination instrument panel, 1998 to 09.99 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Polo Blue Motion: BMS System Upload
No new posts Touran 1.9 TDI Fuel Consumption: With/Without BlueMotion Diesel Engine Technology
No new posts AdBlue Countdown: No Error Messages Diesel Engine Technology
No new posts AdBlue error keeps recurring Diesel Engine Technology
