TDI PD115: Timing Belt Change - What to Replace?
RalfBru
Post20-01-2003, 9:31    Subject: TDI PD115: Timing Belt Change - What to Replace? Quote
What would you replace while the timing belt is being changed on a BMW M3, especially since so much needs to be disassembled anyway?
Timing belt...
Tension rollers...?
Timing belt...?
What about the water pump specifically? Should it be replaced immediately, or not? Are there any other parts that might need to be checked?
Ralf.
Translated on 17-08-2026, 12:57.
No new posts Timing belt replacement on a 1.9L PD TDI Troubleshooting & Guides
No new posts Timing belt replacement Audi A6 4F, BRE engine 2.0 TDI PD Troubleshooting & Guides
No new posts Timing belt replacement for transversely mounted PD engine Troubleshooting & Guides
No new posts Performance fluctuations in PD115 Diesel Engine Technology
No new posts Annual mileage 74,000 km, 54,000 miles, all in good condi... Upload
No new posts TDI Log: Is Everything OK? Upload
No new posts Fix 00575? Everything OK? Upload
