Different plug connectors?
New Topic Reply 🔗 🖨 Dieselschrauber - Index » On-Board Diagnostics (OBD)
tatanka-yo-tanka
Post23-06-2007, 15:33    Subject: Different plug connectors? Quote
I have purchased a set of fuel injectors. The needle hub is from the 110 hp TDI with VAG part number 028 130 201 S. It has a round connector, while my old injectors have a square connector. Does anyone know the ET number for the connector on the engine cable harness? I haven't been able to find it at VW. In the computer, I only ever see the square connectors. For your assistance, I am grateful.
VW Bus T3 mit 1Z Motor aus 94er Passat
christians
Post23-06-2007, 20:17    Subject: Different plug connectors? Quote
1J0 973 722 Housing (cable side)
000 979 133 Cables with Contacts
357 972 741 Individual Seals
Gruß Christian
Post23-06-2007, 21:53    Subject: Different plug connectors? Quote
...or cut the plug from the old NHG and use heat shrink tubing.
Hello, Rainer
tatanka-yo-tanka
Post23-06-2007, 22:47    Subject: Different plug connectors? Quote
Great, thanks for the quick help!!
At VW, they were at a loss.
Greetings
Jürgen
No new posts Needle Valve Actuator: Construction & Functionality Technical Articles
No new posts Fuel Injectors: Different Prices with Needle Lift Control? Diesel Engine Technology
No new posts Verschiedene Düsen für 1Z? Diesel Engine Technology
No new posts Different navigation versions? Diesel Engine Technology
No new posts Different engine part numbers - what does each one mean? Diesel Engine Technology
