bindpe Blaumann
Joined: 08/25/2006 Posts: 203 Karma: +5 / -2 Location: ingolstadt
26-06-2007, 17:31 Subject: ahu: What is this type of ductwork? |
Hello.
Short question about the AHU motor. Can anyone please tell me what kind of hose this is? I've circled it in red in the picture. Mine looks similarly deteriorated, and as you can see in the picture, is this a "critical" hose?
Thank you for your responses.
Best regards, Golf III TDI AHU 402Tkm
Translated on 09-08-2026, 14:12.
Jochen_145 Guest
26-06-2007, 17:51 Subject: ahu: What is this type of ductwork? |
Unfortunately, I can't quite see where it ends. Is it near the oil filter?
Yes, then it is vital for your turbocharger. It's essentially the main artery that supplies oil to the turbocharger.
If it breaks, your engine will 'bleach out' (lose power), unless the turbocharger seizes up first.
Best regards, Jochen.
Translated on 09-08-2026, 14:14.
rubberduck Blaumann
26-06-2007, 18:23 Subject: ahu: What is this type of ductwork? |
This particular line even became slightly leaky because it was deteriorating. I proactively ordered a new line for the warehouse and then replaced it during the next major operation. Wer Rechtschreibfehler findet, kann sie behalten !
26-06-2007, 21:59 Subject: ahu: What is this type of ductwork? |
Oops, sorry.
I wanted to correct the double attachment, but now both of them are gone and I can't undo it.
"But the contributions are correct; it's the oil supply line to the turbocharger. It goes into the top of the turbo, and the oil returns to the engine block from the bottom."
Okay, please provide the German text you would like me to translate into English. I will only provide the translation. Transparency, Teamwork
Translated on 09-08-2026, 14:15.
Profile PM Garage |
bindpe Blaumann
27-06-2007, 5:55 Subject: ahu: What is this type of ductwork? |
hello
No problem about the picture. Thank you for the answers. Can anyone tell me the part number or how to best obtain this part? Or perhaps sanding it down and treating it with rust protection would be a good option?
Translated on 09-08-2026, 14:16.
27-06-2007, 15:19 Subject: ahu: What is this type of ductwork? |
Sanding is a tricky thing:
- If it's installed, you'll get a decent result.
- If you take it apart, you'll have the problem of how to clean the inside afterwards, because the oil inside should be "clinically clean," as the turbocharger shaft is floating within it.
Translated on 09-08-2026, 14:17.
Profile PM Garage |
