cksIT Blaumann
Joined: 05/22/2004 Posts: 399 Karma: +18 / -0 Location: Riedstadt
12-06-2007, 8:20 Subject: |
No, it's a right-hand thread.
But if you can't achieve anything with a wrench, I doubt you'll be able to do much with a sliding hammer.
"Hey Rainer, why would WD-40 cause problems? I've always used it normally, but if it shouldn't be used, I would have used penetrating oil or something similar instead..." Man muss es nicht brauchen, aber man muss es haben!
Translated on 13-10-2026, 7:11.
Joined: 04/12/2002 Posts: 18128 Karma: +803 / -0 Location: St.Gallen 2018 Volkswagen T6
12-06-2007, 8:36 Subject: |
M14x1.5 right-hand thread.
Profile PM WWW Garage |
Jens 16syncro
12-06-2007, 11:38 Subject: |
Rainer K. wrote: | | M14x1.5 right-hand thread |
Thank you.
I'm going to make an adapter for the sliding hammer; it's better than messing around with welding.
The nozzle holders are all securely fastened, and you can tighten them firmly with a 15mm open-end wrench or an adjustable wrench with an extension; there's absolutely no problem.
Jens. Marcus "Ar Gwenn": Für uns sind Leute arm, weil sie mit einem Eselskarren unterwegs sind, für sie sind wir arm, weil wir ein Leben lang dafür arbeiten und Geld verdienen müssen, um uns im Alter von wildfremden Leuten pflegen zu lassen.
Translated on 13-10-2026, 7:12.
12-06-2007, 11:54 Subject: |
Quote: | | @rainer why would WD-40 cause problems? |
The rust and fine dust that sits in the gap between the nozzle holder combination and the ZK (presumably a connector or housing) gets soaked, and based on experience, this causes even "normally secure" nozzle holder combinations to become even more firmly stuck.
A dry build-up method has always worked most reliably for me when the water temperature is warm or hot.
Translated on 13-10-2026, 7:13.
dieselcruiser Guest
12-06-2007, 14:04 Subject: |
To achieve a better pull, you can also screw on a tie rod end (!), which has the same thread.
Translated on 13-10-2026, 7:14.
christians Profi-Schrauber
13-06-2007, 11:38 Subject: |
Constantly wiggling the adjustable wrench back and forth, never applying enough force to break the threaded housing, has sometimes helped. At first, you won't see any movement, but eventually, the rust will give way. Gruß Christian
rubberduck Blaumann
13-06-2007, 17:45 Subject: |
Okay, I've also had the problem with extremely stuck threaded connections before. I bought pure penetrating oil at the hardware store, without any additives or lubricants. Then, I soaked the threads with it every day for a week. After a week, the threads could be moved a little. Then, I used a 15mm wrench with an extension to move them back and forth. It takes a little time, but it works.
I've also encountered situations where the threaded fitting at the bottom of the fuel injector came loose due to repeated assembly and disassembly. In those cases, nothing would work. Since the cylinder head was already removed, we screwed in an old fuel injector and then pushed the entire assembly out from the cylinder side. Wer Rechtschreibfehler findet, kann sie behalten !
Translated on 13-10-2026, 7:15.
Jens 16syncro
18-06-2007, 16:24 Subject: |
I reinstalled the rebuilt turbocharger, and the engine is running again.
I followed Rainer's instructions, so I loosened the mounting screws of the tensioning arms and started the motor to warm it up.
Then, I used the large wrench and the drift hammer again.
Nothing is moving  .
*grmfx*
Translated on 13-10-2026, 7:16.
18-06-2007, 16:36 Subject: |
Quote: | | Warm up the engine. |
Not warm, but full throttle.
It's best to always drive diligently at 2200 rpm, fully accelerating and then releasing the gas. However, after about 10 km, these things will start to fail and begin to break down.
Translated on 13-10-2026, 7:18.
Jens 16syncro
18-06-2007, 16:46 Subject: |
Rainer K. wrote: | Not warm but full throttle.
It's best to always use full throttle consistently at 2200 rpm, but avoid sudden changes. After about 10 km, they will likely start to fail and begin to degrade.
Okay.
I'm trying to do that when my turbocharger is properly controlled again  .
Currently, I suspect that the N75 valve is not functioning as it should (see another thread).
Translated on 13-10-2026, 7:19.
Jens 16syncro
18-06-2007, 16:49 Subject: |
One more quick question:
How much should the tensioning screws be loosened?
One rotation? Marcus "Ar Gwenn": Für uns sind Leute arm, weil sie mit einem Eselskarren unterwegs sind, für sie sind wir arm, weil wir ein Leben lang dafür arbeiten und Geld verdienen müssen, um uns im Alter von wildfremden Leuten pflegen zu lassen.
Translated on 13-10-2026, 7:20.
18-06-2007, 17:33 Subject: |
2mm of clearance at the bracket.
Jens 16syncro
02-07-2007, 5:34 Subject: |
Translated on 13-10-2026, 7:21.
