ECU Login Code: How to Find & Use
Tins
Post06-07-2007, 17:54    Subject: ECU Login Code: How to Find & Use Quote
Hello, I have a problem. I want to activate the cruise control. I have VAG Com version 311... Where can I find the settings to enable the cruise control? I have a control unit from a 1Z model. I also don't know the code to access the engine control unit. Can anyone help me?
Thank you in advance.
Regards, Tins.
Translated on 03-09-2026, 4:40.
mullemaus
Post06-07-2007, 18:47    Subject: ECU Login Code: How to Find & Use Quote
Have you ever browsed the forum for this? The activation codes for the cruise control should be found there. Search is your friend icon_wink.gif.
Translated on 03-09-2026, 4:41.
No new posts Login Codes TDI / VAG Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts HEX-V2: Login failed Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts ABS Control Module 6X0 907 379B - Error Code 00668 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Login Code for Comfort Control Unit Diesel Engine Technology
No new posts AEL Motor Login Code: Start Quantity Example On-Board Diagnostics (OBD)
This topic is locked, you cannot edit or reply. 7-Digit Login Code: Find & Generate Now On-Board Diagnostics (OBD)
No new posts Looking for login code for comfort control unit On-Board Diagnostics (OBD)
