Dirk67 Guest
17-01-2003, 13:14 Subject: Shorten Throw Distance: How To & Guide |
Is it possible to shorten the shift travel on my gearbox (CEP in a C4 TDI)?
(are extremely long)
Please provide the German text you would like me to translate into English.
Translated on 30-10-2026, 1:38.
17-01-2003, 14:04 Subject: Shorten Throw Distance: How To & Guide |
You can cut off 6cm of your gear lever.
Profile PM WWW Garage |
Dirk67 Guest
17-01-2003, 14:14 Subject: Shorten Throw Distance: How To & Guide |
I was already expecting that answer.
But that's exactly what I didn't mean.
Jan6K
18-01-2003, 11:18 Subject: Shorten Throw Distance: How To & Guide |
"Some people in the Polo forum have come up with a solution, although it's not designed for cable-operated gearboxes. However, the basic idea should work, and it's probably even simpler. They shift the "pivot point" of the lever upwards, which makes the lower part longer. This results in the same actuation distances being achieved with smaller lever angles – which is exactly the goal."
If we apply this to a cable-operated system, you would essentially need to modify the control box that actuates the cables so that this effect occurs. This would involve raising the pivot point of the lever, allowing the same cable pull to result in smaller lever movements.
You can't bypass the principle of leverage with that; it will simply require more force.
Jan. 1Z5 CFHF  / AHB H4D
Translated on 30-10-2026, 1:39.
soave Guest
18-01-2003, 23:35 Subject: Short Throw Distance: Reduce Throw Distance |
Hello!
Check it out under.
http://www.gema-motorsport.de/
mild, gentle, soft, pleasant
Translated on 30-10-2026, 1:41.
Markus H. Guest
19-01-2003, 12:28 Subject: Shorten Throw Distance: How To & Guide |
Hi Jan,
As far as I know, the C4 Audi 100 doesn't have a cable-operated gear shift, but rather shift rods.
Thomas K Blaumann
20-01-2003, 15:04 Subject: Shorten Throw Distance: How To & Guide |
The company www.bmracing.com offers gear shift levers for various vehicles, which reduce the shift travel by 25-50%. Gruß Thomas
VW EOS 2,0 TSI; BWA; Bj. 06/2006
September 2020 ca. 180.000km
VW Bora Variant, AJM, Bj. 04/2001
04/2016 verkauft mit 378.000km
Bertil Profi-Schrauber
20-01-2003, 19:03 Subject: Shorten Throw Distance: How To & Guide |
Markus H. wrote: |
As far as I know, the C4 Audi 100 does not have a cable-operated gear shift, but rather shift rods. |
... No problem, I also provide information for articulated linkage systems...
In my Jetta 1, there is a VW Motorport replica engine.  Gruß Bertil
Translated on 30-10-2026, 1:42.
Thomas Profi-Schrauber
Joined: 04/17/2002 Posts: 329 Karma: +2 / -0 Location: Darmstadt
20-01-2003, 22:05 Subject: Shorten Throw Distance: How To & Guide |
Just to get the basic idea.
When I look at a rally car or something similar, it's often even longer than the standard production version.
What's the point of shortening the gear stick then?
If reducing the throw requires more force, wouldn't it be appropriate to lengthen the lever?
Greetings.
Thomas. -----------------------------------------------------
Audi S2 ADU Bj. 1993
Audi A3 TDI ASZ Bj. 2001
Translated on 30-10-2026, 1:43.
Markus H. Guest
20-01-2003, 23:21 Subject: Shorten Throw Distance: How To & Guide |
Well, I think in the case of racing or rally applications, it's probably less about having comfortable shifting with minimal effort.
It probably depends more on shortening the switching time through a shorter switching path (less interruption of traction force, etc.).
...and you have your hands free for longer to hold the steering wheel...
Translated on 30-10-2026, 1:44.
21-01-2003, 7:08 Subject: Shorten Throw Distance: How To & Guide |
Thomas wrote: | Hi,
What's the point of shortening the gear shift lever?
You've misunderstood something!
It's not the lever itself that's being shortened, but the travel of the gear lever, which allows for faster gear changes (as Markus already explained)!!
The set for my Jetta also included a gear shift knob extension to bring the gear shift lever closer to the steering wheel. However, you then need to shorten the shift travel using the linkage on the transmission.
Modern rally cars often have sequential gearboxes, which offer complete freedom in terms of gear shifting using the lever. The gear levers themselves are also typically very long.
Something else.
Anyone who wants to install a shorter cable routing system should be aware of two things:
The amount of force required to shift gears is significantly higher, and a jerky transmission doesn't exactly make things easier.
"The load on the synchronizer rings of the gearbox is significantly higher due to the potentially faster shifting. This can sometimes cause a loud clunking noise when shifting, which increases wear and tear inside the gearbox. I've destroyed numerous gearboxes and drive shafts in my rally car!" Gruß Bertil
Translated on 30-10-2026, 1:46.
21-01-2003, 21:44 Subject: Shorten Throw Distance: How To & Guide |
I was just wondering why people would cut off the gear stick and then screw on a generic knob. (Rainer suggested this).
I understand what you mean about the faster shifting.
Therefore, I also thought that when shortening the throw of the lever, the lever arm would be increased due to the leverage effect.
So far, I've only removed that stupid switch weight from my own setup.
Regardless, what I was mainly concerned about was the cutting.
Naja. See you later.
Translated on 30-10-2026, 1:48.
22-01-2003, 11:58 Subject: Shorten Throw Distance: How To & Guide |
Thomas wrote: | That's why I also thought that when shortening the throw of the lever, you would increase the lever arm length due to the leverage effect.  |
You can certainly do that, but then you won't have gained anything.
Okay, gib mir den deutschen Text.
- First, by modifying the transmission components responsible for gear selection, the shift travel from 1st to 2nd gear is reduced from 10cm to 5cm.
- Now, it naturally becomes "more difficult" to shift gears, and more force is required to change gears.
- If you extend the gear lever to require less force, the gear throw will simultaneously become longer...
Translated on 30-10-2026, 1:49.
