Inspection Interval Data
UdoZ
Post05-07-2007, 17:16    Subject: Inspection Interval Data Quote
ich habe - ein wenig Spielerei - bei meinem 2001er T4 (7DC, LongLife mit CAN-Bus-Kombiinstrument) die Service-Intervall-Anzeige über die Knöpfe am Tacho zurückgesetzt. Wie es im Prospekt steht, wurde dadurch auf ein festes Intervall 'zurückprogrammiert'. Die Grenzwerte (Kanäle 43 und 44) wurden korrekt auf 15.000/365 gesetzt, die Werte für km/Tage seit Inspektion (Kanäle 40 und 41) auf 0. So weiOkay, very good.
'I have now entered the data for kilometers driven per day since the last inspection, adjusting it to 40/41. Surprisingly, the odometer displays 'Service in 3000 km' at any mileage above 12,000 km, for example, when I enter 14,500 km. I would have expected that mileage to display 'Service in 500 km.' However, the countdown from 3000 km is working correctly.'
Why does the display always show '3000' after the adjustment, instead of the correct kilometer reading up to 15,000 km?
Bug? Feature? Misuse?
Thank you in advance, UdoZ.
Translated on 04-09-2026, 7:56.
Ross-Tech-Support
Post08-07-2007, 3:43    Subject: Inspection Interval Data Quote
Did you reset the service between the attempts?
Translated on 04-09-2026, 7:57.
UdoZ
Post08-07-2007, 8:36    Subject: Inspection Interval Data Quote
The '3000' appeared regardless of whether I had paused or not.
Even though the display showed a lower value due to driving (e.g., 2700), simply adjusting channels 40/41 resulted in the display showing '3000' again, indicating more kilometers driven since the last inspection.
Translated on 04-09-2026, 7:58.
GTI
Post12-07-2007, 1:09    Subject: Inspection Interval Data Quote
What number did you enter for "Days since the last inspection"?
Tiguan Life Bj 2014 7-Gang DSG 2,0 TDI 4-Motion 177PS
Translated on 04-09-2026, 7:59.
Back to top Profile PM Email
UdoZ
Post12-07-2007, 19:10    Subject: Inspection Interval Data Quote
I tried using intervals of 100 to 200 days.
GTI
Post14-07-2007, 23:57    Subject: Inspection Interval Data Quote
But let's talk about something else...
Is this remapping of the display something you need, or are you just doing it for fun?
"Actually, you can do your inspection whenever you think it's right, regardless of what the display shows. Then, you can reset it using the buttons on the dashboard, and you'll be back on track."
No new posts VW Golf 4 Inspection Interval: 2002 Model Diesel Engine Technology
No new posts Engine Control Unit (ECU) Data Diesel Engine Technology
No new posts VW 1.6 TDI CR Specs: New Model Technical Data Diesel Engine Technology
No new posts Data for the 2.0 16V engine with filter Diesel Engine Technology
