PD-TDI Replacement ECU | Control Unit
_Mike_
Post15-07-2007, 4:26    Subject: PD-TDI Replacement ECU | Control Unit Quote
I want to install a PD-TDI engine into a T3 without using the original engine control unit (ECU).
In the motorsport sector, there are "freely programmable" engine management systems for gasoline engines, and I was hoping that someone in this forum might know of companies or individuals who manufacture similar systems for diesel engines.
Thank you in advance.
Mike.
Translated on 31-10-2026, 23:42.
Post15-07-2007, 11:28    Subject: PD-TDI Replacement ECU | Control Unit Quote
Hello Mike,
Bosch Motorsport offers such products, but the price is completely irrelevant for a hobby project.
I can perform a reasonable adjustment with the engine control unit, possibly including a reduction in the maximum torque.
Actually, there's no real need to modify this motor with a custom-programmable system, because you can already modify all the necessary functions as desired using the standard engine control unit. Additionally, you have the advantage of already having a reasonable and tested foundation, so you don't have to reinvent the wheel.
Translated on 31-10-2026, 23:43.
_Mike_
Post15-07-2007, 18:46    Subject: ECU: Steuergerät kaufen | Steuergerät wechseln Quote
Hello Rainer,
You have a private message.
Mike.
Translated on 31-10-2026, 23:44.
No new posts VW T6, rear shock absorbers - replacement / weak performance Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts ABS Control Module 6X0 907 379B - Error Code 00668 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts LMM 038 906 461: Replacement for 06A 906 461 On-Board Diagnostics (OBD)
No new posts Outsmarted the STG again... LMM replacement Diesel Engine Technology
No new posts Ersatz für gerissenen Kühlwasserstandsanzeiger? Diesel Engine Technology
No new posts Boost pressure sensor faulty - looking for replacement On-Board Diagnostics (OBD)
