1Z steuergerät ohne WFS ? | Posts 16+
Go to page: Previous  1, 2
mullemaus
Post06-05-2007, 13:44    Subject: Quote
That was my question, which one do you need? 10-pin or 12-pin? With a reading coil? How many transponders? My crystal ball is currently being repaired icon_wink.gif.
http://de.wikipedia.org/wiki/Reparatur icon_redface.gif icon_lol.gif
Translated on 13-09-2026, 5:22.
boofrost
Post06-05-2007, 17:17    Subject: Quote
Unfortunately, I can't tell you whether it's a 10-pin or 12-pin connector... Does the box have 12 cables coming out of it? I don't think I have that many spare cables in my stock... I don't think I have ten either... I'll call the electrician. Yes, I'll need a reading coil and a key... I'll put all this stuff in the corner... It's not going to be mounted in front of the ignition switch.
Do you have something like that? I'll call the electrician later and see if he's familiar with 10 or 12-pin connectors...
Best regards and many thanks.
Translated on 13-09-2026, 5:23.
boofrost
Post12-05-2007, 12:57    Subject: Quote
Okay, so I just went to VW... he said the WFS control unit has 6 pins... and I can't remember if it's 10 or 12 pins... so apparently it has 6 pins, and I'll also need the key for that.
or I still need someone to remove the WFS, which can only be a sign...
Does anyone have a WFS control unit and key for me? He he.
Best regards, Paul.
Translated on 13-09-2026, 5:24.
frebert
Post12-05-2007, 13:12    Subject: WFS Connector Pinout: 8-Pin (e.g., VW Polo 6N '97) Quote
Can someone tell me the pinout for the WFS-STG, which has 8 pins?
I connected it like this once:
Pin 1 --> Constant 12V positive power supply.
Connect pin 2 (ignition, positive terminal, circuit 15) on the MSG to pin 38.
Pin 3, nothing.
Connect pin 4 and pin 5 to ground (MSG pin 24).
Pin 7 to MSG, pin 61.
Connect pin 8 on the diagnostic connector to the pin where the gr/ws wire from MSG pin 61 was previously connected.
Now VAG-COM is showing an error (interface or K-line etc. is defective, or similar).
What's wrong?
If I disconnect the K-line from the WFS-STG and connect it directly from the MSG to the diagnostic connector, I can normally read the engine data.
Thank you very much for your help.
Best regards, Frebert.
1,9 l AFN mit Schick Wasser LLK im T3
Translated on 13-09-2026, 5:26.
boofrost
Post12-05-2007, 13:14    Subject: Quote
lol? You probably would have needed to start a whole new thread for that, right?
Translated on 13-09-2026, 5:28.
frebert
Post12-05-2007, 13:26    Subject: Quote
I didn't dare icon_biggrin.gif.
Please tell me what I did wrong again! I just don't understand!
And I've now also created a new post... you'll hear about it from that icon_biggrin.gif.
boofrost
Post13-05-2007, 1:02    Subject: Quote
As a liquid cooling system, I have a quattro liquid cooling system with aluminum housings, used for water cooling, but that particular one would need a different wall. icon_smile.gif
but I still can't drive because of the WFS... guuuuuuuys need help icon_sad.gif
Translated on 13-09-2026, 5:29.
rubberduck
Post13-05-2007, 9:29    Subject: Quote
... that can only be a signal...
That was exactly my thought as well. But what kind of signal does the engine control unit need? Admittedly, a 5V positive voltage would be too simple icon_lol.gif. It can only be some kind of positive/ground signal. You should connect an oscilloscope to it... icon_wink.gif
Translated on 13-09-2026, 5:30.
boofrost
Post13-05-2007, 11:52    Subject: Quote
Here's what I think is a good idea icon_smile.gif. I just bought a B control unit from a book, hopefully it doesn't have WFS... but for 80 euros, it's still a good deal..
I'm looking forward to the day it arrives here.
boofrost
Post13-05-2007, 21:17    Subject: Quote
Okay, I just spoke with him. He converted his 3-series to run on AFN, and had to retrofit the WFS. His car definitely DID NOT have... so the control unit doesn't either icon_smile.gif. I think that's VERY NICE icon_smile.gif, and that for 90 euros... icon_smile.gif
ooooooooooooooooooh how beautiful it is ^^ icon_biggrin.gif icon_biggrin.gif icon_biggrin.gif icon_biggrin.gif icon_biggrin.gif
Translated on 13-09-2026, 5:31.
Rudi
Post14-05-2007, 8:21    Subject: Quote
ooooooooooooooooooh how beautiful ^^ icon_biggrin.gif icon_biggrin.gif icon_biggrin.gif icon_biggrin.gif icon_biggrin.gif
Freu dich nicht zu früh. Mir ist noch kein 021C mit WFS untergekommen. I'm afraid that...
The 021B update will not significantly change the vehicle's handling.
Rudi.
Translated on 13-09-2026, 5:32.
boofrost
Post19-05-2007, 7:05    Subject: Quote
The 021 B definitely doesn't have that... I already installed it. But now my car is doing other things; it runs for a while, then dies after about 30 seconds. It dies, but the engine doesn't stall. It's like it's not getting any diesel. Also, unfortunately, the car didn't accelerate at all during those 30 seconds when it was running.
Can the gaspoti be checked?
Translated on 13-09-2026, 5:33.
boofrost
Post17-07-2007, 8:41    Subject: Quote
Okay, to finish things up... The bus is running, but it keeps going into limp mode, and my coolant hose connections still need to be reworked. However, I've now managed to buy a second B control unit, and it also doesn't have the WFS (presumably a specific feature or module).
Thank you everyone!
Translated on 13-09-2026, 5:34.
No new posts Power loss without soot Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts T5 Brake Fluid MIL: No Function Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Door Lock Malfunction: A6 4B Documentary Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts ECU Programming: How to Learn/Calibrate On-Board Diagnostics (OBD)
No new posts B4 TDI ECU: Troubleshooting & Repair On-Board Diagnostics (OBD)
No new posts AAT/AEL Control Unit: Function & Troubleshooting On-Board Diagnostics (OBD)
No new posts control unit settings On-Board Diagnostics (OBD)
