didl Guest
19-01-2003, 14:03 Subject: New fuel injectors for 1Z engine |
I need new fuel injectors for my 1Z engine. Which injectors from which TDI models (engine code) are compatible? Perhaps even larger ones for tuning purposes!
I found these on eBay! Do they fit (mechanically)? Or are they too big, or do they have a different spray pattern?
http://cgi.ebay.de/ws/eBayISAPI.dll?ViewItem&item=3108126244&category=28580
http://cgi.ebay.de/ws/eBayISAPI.dll?ViewItem&item=3108855051&category=28606
'Didl' is a German word that means 'a small amount of something.' It can be used to describe anything from a tiny speck of dust to a large pile of sand.
Here are some examples of how to use the word 'Didl':
* 'There was only a Didl of sugar left in the jar.'
* 'The children were playing with a Didl of sand on the beach.'
* 'I saw a Didl of a bird fly by my window.'
'Didl' is a versatile word that can be used to describe anything from something very small to something relatively large. It is also a fun and playful word, which makes it perfect for use in children's stories or other lighthearted contexts.
Translated on 18-07-2026, 1:32.
haehnlein Schrauber
Joined: 08/22/2002 Posts: 877 Karma: +6 / -0 Location: Griesheim
19-01-2003, 14:26 Subject: New fuel injectors for 1Z engine |
I also have a question about that.
Der Verkäufer (carsten30 oder so) haut ständig nagelneue Einspritzdßsen raus (letztens MKB ein AGR kompletter Satz fßr 100 Euro  ) Ich habe mir letztens einen nagelneuen NGH von einem anderen Verkäufer fßr den 1Z ersteigert->angeblich Unfall und deshalb konnte der Verkäufer den neuen NHG nicht mehr einbauen. Das komische war, dass der Verkäufer in dieser Woche drei Unfälle gehabt haben muss, denn er hat unter verschiedenen Nicknamen neue Nadelhubgeber verkauft->also blabla. DeThe price was naturally still below the wholesale price, even without a replacement!
THERE MUST BE A CHEAP SOURCE FOR INJECTORS  BLOS WO  HUNGARY  SLOVAKIA  . Here, thanks to Skoda, there are many TDIs.
What do you mean?
Best regards, Christian.
Translated on 18-07-2026, 1:34.
werwolf07 Guest
19-01-2003, 18:34 Subject: ESD at Carsten's... |
'... so, I was one of those who bought a complete set of ESD parts for an A3 with an AGR engine from carsten30 â what can I say: the quality was okay, everything was original... and it's already installed...'
So, all things considered, there's nothing to complain about!
Best regards, wolf
Translated on 18-07-2026, 1:35.
Stefan Guest
20-01-2003, 10:00 Subject: New fuel injectors for 1Z engine |
Maybe he works at Bosch in the warehouse...
Tagessuppe Profi-Schrauber
Joined: 11/13/2002 Posts: 1140 Karma: +36 / -0 Location: Wien 2001 Audi A2  Premium Support
20-01-2003, 13:25 Subject: Re: New fuel injectors for 1Z engine |
didl wrote: | Hello,
I found these on Ebay! Do they fit (mechanically)? Or are they too big, or do they have a different spray pattern?
Didl | .
So, the nozzles would fit.
But I wouldn't install them without modified software.
because they have a different nozzle diameter.
However, there is also an offering from Tuneline.
Where can I find the fuel injectors for a VW Caravelle with 150 horsepower?
"to install it and increase the engine's power from 90 horsepower to 170 horsepower."
http://www.tuneline.at/presse/BugsBeetle/story16.htm
Translated on 18-07-2026, 1:37.
Profile PM Garage |
Stefan Guest
20-01-2003, 13:46 Subject: New fuel injectors for 1Z engine |
Yes, yes. 170 horsepower achieved only through a chip tune and fuel injectors. *lol*
Why does a renowned tuner like ******** only achieve 'just' 168 hp? ******** completely overhauled the engine, including a different turbocharger (the standard one wouldn't last two weeks), a different intake manifold, and so on.
They're probably using some kind of magic or something at Tuneline.
Just reading this nonsense makes me wonder whether I should laugh or cry.
'For example, the scene depicts that all the racing TDIs are equipped with *****'s software - software that is not only fast but also durable.'
Sure. VW Motorsport buys its chips from Tuneline. Hahaha... those factory engineers are all overpaid idiots who don't know anything.
But here comes yet another escalation of unqualified rambling and self-praise:
Vom mehr oder weniger ßblichen Chip-Tuning hebt sich ***** insofern ab, als er nicht nur in den Kennfeldern surft, sondern tief in die eigentlichen Programmabläufe eintauchen kann. Die Steuergeräte sind nämlich in Wahrheit mit mehreren Sperren versehen, um nicht jedem, der einen Computer bedienen kann, auch alle Geheimnisse preiszugeben. Man mag sich das durchaus als hßbschen Dialog vorstellen - das Steuergerät signalisiert eindeutig: Bis hierher lieber Tuner, aber nicht weiter. EIf you are clever enough to overcome the next limitation, you have the necessary know-how to extract even more performance without any loss.
This is called a checksum. Any basic tuning software can correct it. Even if the tuning software has access to Damos information, it's not a secret for other tuners.
However, a test bench adjustment and an increased idle speed are then absolutely necessary.
Yes, yes. Increased idle speed... *lol*
I'm driving a completely rebuilt AFN engine with these injectors. My idle speed is the same as stock. A friend of mine also installed these injectors, and his idle speed is also normal.
How can so much compressed nonsense be crammed into so little text???
As I mentioned in another thread: it's impossible to achieve more than 140 horsepower with a stock engine that only has 90 horsepower, even with a chip and injectors.
I've installed a highly tuned chip, large injectors, a big turbocharger (1.5 bar boost), a different intake manifold, and so on, and I'm currently getting just over 160 horsepower.
It's likely that the editor of 'Autorevue' either didn't listen properly or KĂśbl himself told him that nonsense.
Translated on 18-07-2026, 1:41.
haehnlein Schrauber
22-01-2003, 19:36 Subject: New fuel injectors for 1Z engine |
Stefan wrote: | Maybe he works at Bosch in the warehouse...  |
Hi Stefan,
almost perfectly typed... the package with my new NHG from eBay came from Wolfsburg  .
Translated on 18-07-2026, 1:44.
Stefan Guest
22-01-2003, 20:08 Subject: New fuel injectors for 1Z engine |
You should probably leave your WebmasterPlan links as they are!
You can do your pay-per-click stuff somewhere else!
Nobody wants that here!
Translated on 18-07-2026, 1:45.
haehnlein Schrauber
22-01-2003, 20:57 Subject: New fuel injectors for 1Z engine |
Hi Stefan,
Are you talking to me  ? I just typed the word "eBay" and then it seems like an advertisement link appeared... sorry, you have to complain to Rainer about that, not me  .
23-01-2003, 8:34 Subject: New fuel injectors for 1Z engine |
I have to agree with Haehnlein on that point.
That can be translated using many words, for example, "insurance."
eBay, etc.
You can complain in another forum.
but not here!
Translated on 18-07-2026, 1:46.
Profile PM Garage |
Joined: 04/12/2002 Posts: 18092 Karma: +799 / -0 Location: St.Gallen 2018 Volkswagen T6
23-01-2003, 11:55 Subject: New fuel injectors for 1Z engine |
Stefan wrote: | You should probably leave your webmasterplan links alone!
Hi Stefan,
Haehnlein is innocent. Since so many links to eBay have been posted here, I decided to link the word "eBay" itself.
It's not pay-per-click; it's a pay-per-eBay-registration-for-new-users model.
"What problem do you see in the fact that I already have indirect 'advertising' and links for eBay on my server? Then eBay could also send me money if they gain new users as a result."
For the users of my website, the only difference is that when they are browsing eBay, they can easily access my page as well.
Translated on 18-07-2026, 1:47.
Profile PM WWW Garage |
Markus H. Guest
23-01-2003, 19:01 Subject: New fuel injectors for 1Z engine |
For the users of my website, the only difference is that when they are reading eBay, they can immediately go to my page as well.
No. Because in this way, everyone who posts unintentionally promotes something.
At the very least, there should be somewhere in the forum that explains which terms are linked (or does that already exist? If so, sorry).
Translated on 18-07-2026, 1:49.
23-01-2003, 20:02 Subject: New fuel injectors for 1Z engine |
Hello Markus,
I will create a list and include it in the "Terms of Use & FAQs" section.
That might take some time, as I'm currently very busy.
Translated on 18-07-2026, 1:50.
