10 Cent Tuning: Is it the same as...?
mfg!
Post25-01-2003, 4:07    Subject: 10 Cent Tuning: Is it the same as...? Quote
Hello.
My friend bought an A3 TDI. According to the previous owner, the fuel injection pump was removed and the potentiometer was adjusted.
Well, essentially, that's the same thing as the '10-cent tuning' method, isn't it? The engine isn't very powerful; it originally had 90 horsepower, but now it has 118 horsepower according to the dynamometer test.
Okay, so what exactly was adjusted (potentiometer)?
Perhaps you could help us.
Best regards!
Translated on 07-07-2026, 4:20.
Post25-01-2003, 12:10    Subject: Re: Is "10 Cent Tuning" the same as...? Quote
Well, essentially, that's the same thing as the "10-cent tuning" method, isn't it? The engine isn't very powerful; it originally had 90 horsepower, but now it has 118 horsepower according to the dynamometer test.
Now, what exactly was adjusted (potentiometer)?
Hi.
If it's a pump with an HDK sensor, such an improvement wouldn't be possible without a flashing preheating lamp and/or noticeable jerking in the partial load range --> Technical article on RWG (likely referring to a specific technology or system).
I don't know how that applies to very old Pottinger pumps (do they use round instead of oval 7-pin connectors?).
Translated on 07-07-2026, 4:22.
mfg!
Post25-01-2003, 20:15    Subject: 10 Cent Tuning: Is it the same as...? Quote
Hi.
Okay, so the preheating light isn't blinking. Slight vibration only in the lower RPM range (around 1000-1500 RPM), barely noticeable, but if you're paying attention, you can detect it.
Well, considering the age, it's a 1997 model, so I don't think it has the older type fuel injectors, do you think?
Thank you.
Translated on 07-07-2026, 4:24.
Post25-01-2003, 22:40    Subject: 10 Cent Tuning: Is it the same as...? Quote
mfg! wrote:
Well, regarding the age, it's a 1997 model, so I don't think it has the old potentiometer pumps, do you?
Hi.
"As far as I know, the 1997 models definitely came with the HDK pump."
I don't believe it has 118 horsepower. It seems the measurement was likely greatly exaggerated, and it's probably that the engine was quite powerful from the factory.
For example, from 98 to at best 110 horsepower, okay...
Translated on 07-07-2026, 4:25.
No new posts 10Cent Tuning Technical Articles
No new posts Tuning: Intake & Intercooler - Optimization Guide Technical Articles
No new posts Fuel injector replacement: Tuning without electronic modi... Technical Articles
No new posts 10 Cent Tuning Diesel Engine Technology
No new posts Tuning Chip for VW T4 2.5L 75kW - 10 Cent Diesel Engine Technology
No new posts 10 Cent Tuning warum Pin 2 und 3 ?????? Diesel Engine Technology
No new posts Diodes 20 Cent Tuning Diesel Engine Technology
