Am VTG Gestänge drehen? | Posts 16+
Go to page: Previous  1, 2
Post04-07-2007, 12:59    Subject: Quote
The VTG basic function can be observed with constant full throttle from approximately 1300 to 4500 rpm in 3rd gear or higher, with MWB 11 being logged.
In this case, the full throttle can be determined with sufficient accuracy based on the desired load curve, so other measuring devices are not initially necessary.
Yes, if he keeps up the good work, definitely.
I hadn't seen Ulf's request for the log, which is why I made that comment.
m
Translated on 26-09-2026, 15:21.
polo2f
Post29-07-2007, 4:44    Subject: Quote
hello
Yesterday, I disassembled my old charger.
What usually gets stuck with the VTG hot-end clamp? Basically, I can only fit the current turbocharger into the old exhaust housing. The adjustment lever can't be changed, if I'm seeing correctly?
'Hello'
paul
Translated on 26-09-2026, 15:22.
polo2f
Post03-08-2007, 20:29    Subject: Quote
Okay, it worked pretty well. I managed to fit my charger into the other exhaust housing. I've driven about 700 km since then, and the problem hasn't reappeared yet.
'Hello'
paul
Translated on 26-09-2026, 15:23.
This topic is locked, you cannot edit or reply. How to make longer VTG rods. Diesel Engine Technology
No new posts Adjust VTG Rods: How-To Guide Diesel Engine Technology
No new posts VTG Rod Too Long? Solutions & Fixes Diesel Engine Technology
No new posts Vintage Rods: Making Them Common Diesel Engine Technology
