VW EDC16 Connector Part Number Lookup
Jochen_145
Post01-08-2007, 15:37    Subject: VW EDC16 Connector Part Number Lookup Quote
Hello everyone,
I am looking for the VW part number for the large, 81-pin EDC 16 connector.
This is similar to the 81pol EDC15 connector with the VW part number 1J0906385C.
However, the EDC16 connector is cheaper because it is supplied without contacts.
Could someone please check the records or a vehicle?
The spare parts program at AUDI was simply too opaque.
If it's not too much trouble, the number of the small 40-pin connector would also be very helpful icon_smile.gif.
Sure, here's the translation:
'Thank you.'
Best regards, Jochen.
Translated on 21-10-2026, 5:41.
Ross-Tech-Support
Post02-08-2007, 15:47    Subject: VW EDC16 Connector Part Number Lookup Quote
How about 3C0-906-379? I think that should work for MED9/MED17 and EDC16/EDC17.
Translated on 21-10-2026, 5:42.
Jochen_145
Post06-08-2007, 9:08    Subject: VW EDC16 Connector Part Number Lookup Quote
You're welcome.
Unfortunately, I fell victim to a misunderstanding.
I understood a suggestion that I could use the 81-pin EDC 16 connector instead of the 81-pin EDC 15, and thus save money.
This, however, doesn't seem to be correct, or does it icon_question.gif?
Ross-Tech-Support
Post06-08-2007, 9:18    Subject: VW EDC16 Connector Part Number Lookup Quote
Translated on 21-10-2026, 5:43.
No new posts Pressure Sensor Connector: Find Part Number 1J0906627A Diesel Engine Technology
No new posts EDC16 and ABS 5.7 Electrical Systems, Vehicle Electronics, Multimedia
No new posts Wie erkenne ich EDC16 ECU's? On-Board Diagnostics (OBD)
No new posts EDC16 Data Block 9: Field 4 Explained Diesel Engine Technology
