Golf IV, High RPM, Error in Fault Memory
New Topic Reply 🔗 🖨 Dieselschrauber - Index » On-Board Diagnostics (OBD)
Schorsch987
Post08-08-2007, 17:42    Subject: Golf IV, High RPM, Error in Fault Memory Quote
Hello, I have a problem with a Golf IV, manufactured in 1999, model year 2000, 1.6 petrol engine, engine code: AKL
The engine is running at too high a speed, approximately 950 to 1100 RPM, but sometimes it also operates in the normal range of 860 RPM. Throttle valve has been cleaned and re-adjusted.
During error reading, the following errors were also detected.
00522 (Coolant temperature sensor)
Signal Faulty:
and 00668 Power Supply B+ (Power Supply Faulty)
The battery was temporarily replaced, but the error persists. After upgrading the generator controller, I discovered that the housing is cracked and exhibits typical overheating symptoms. (Will be replaced tomorrow)
Temperature sensor replaced, but it didn't help.
The errors only appear when the engine starts, but after clearing the error, the errors no longer appear when the engine is running.
PS: The following was also noted regarding the parameters:
The lambda probe does not remain constant, but instead permanently fluctuates between 0.1 and 0.9 volts. As if he's trying to sort things out.
One thing I have to say is that the car already has 240,000 km on the odometer.
pax
Avatar-pax
2000 Volkswagen Passat
Post08-08-2007, 20:08    Subject: Golf IV, High RPM, Error in Fault Memory Quote
The temperature sensor has been replaced, but it hasn't made any difference.
Have you checked the resistance value? I think there's a diagram somewhere in this forum showing the characteristic curve. How about the plugs and cables, have you looked into that?
Bye
pax
Schorsch987
Post14-08-2007, 14:55    Subject: Golf IV, High RPM, Error in Fault Memory Quote
So, I was able to measure everything again today.
1. Fault found in the power supply cable, specifically near the control unit.
2. Coolant sensor replaced, but the fault still persists. Wiring checked between the control unit and the sensor. The connection is there, so it can't be the cable either. I haven't noticed any defects either at terminals 70 and 53 on the control unit.
Is there currently a make (short circuit) directly on the control unit? Could it be that a solder joint has come loose?
Who can give me another tip?
scrdel
Karma: +4 / -2   Thank you, like it!
2002 Volkswagen Passat
Post16-08-2007, 22:23    Subject: Golf IV, High RPM, Error in Fault Memory Quote
... maybe the new sensor is also used by the police?
The behavior is consistent with a faulty sensor.
Sensor provides incorrect values, e.g., "Engine cold", resulting in the mixture being "oiled" = RPM increased!
Had a similar error, the cause was the temperature sensor G62.
/viewtopic.php?t=15701&highlight=
Sven
Passat Variant Highline 2,0 TDI 103KW
No new posts VW Golf V/VI and similar models: ABS/ESP error Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku Golf 1J, Problem with the ignition lock Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku Golf 1J MJ 2001, Fehler 01435 im ABS-STG Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts What do the error codes in the error memory mean? On-Board Diagnostics (OBD)
No new posts Fault quantity setting in the fault memory On-Board Diagnostics (OBD)
No new posts MSW 1Z: Many errors after cleaning On-Board Diagnostics (OBD)
No new posts "AdBlue error message, but fault memory is empty." Diesel Engine Technology
