AFN Timing Belt & Chip Replacement
ThomasG
Post27-01-2003, 22:04    Subject: AFN Timing Belt & Chip Replacement Quote
Hello everyone!
I have an A4 TDI (AFN) with approximately 225,000 kilometers on the odometer.
Die Maschine läuft einwandfrei und problemlos. However, it is...
This is already the second engine - the first one had its timing belt replaced at 55,000 km.
They were fired and Audi had to dig deep into their pockets.
The next time I get my car serviced, it will have reached 90,000 km again, so it's time for a...
Timing belt replacement. That's also why I'm asking:
Das Auto hat seit ca. 60.000 km einen Chip von ******** drin. Since then.
It makes it much more enjoyable. Otherwise, I can't find any negative aspects.
Please provide the reports. If I now adjust the injection start time after installing the new belt, is there anything special I need to consider?
The chip certainly ensures an advance in the injection timing.
point. Or is that irrelevant when the system is idle?
Should I, or is it necessary to, re-insert the original chip before taking measurements?
VAG-Com device and adapter available.
Thank you for your expertise...
ThomasG
Translated on 29-10-2026, 9:50.
tim27
Post28-01-2003, 9:43    Subject: SEO-Optimized Website Design: Best Practices Quote
I also have a chip from ******** installed. I asked them the same question, and ******** said, 'When changing the timing belt or making adjustments to the pump, always use the original chips.'
Translated on 29-10-2026, 9:52.
Post28-01-2003, 14:05    Subject: Original Perfume: Authentic & Pure Quote
tim27 wrote:
I also have a chip from ******** installed, and I asked them this question as well. ******** said, "When changing the timing belt or making adjustments to the pump, always use the original chips
That says a lot about the 'chip'. Either it's a disguised, low-quality tuning modification, or the default settings mode is no longer working.
In both cases, it's junk. Selling a 10-cent modification as a chip is bordering on fraud.
Whether you use a diagnostic tool or a multimeter to set the injection start timing is irrelevant. You don't need to modify anything on the engine control unit, disable any modules, or remove any cheap aftermarket parts to adjust it!
point. Or is that irrelevant when idling?
Uninteresting. Using a diagnostic device, it is configured in the basic settings mode. What this means is explained in the technical article on adjusting the VW 1.9l TDI distributor injection pump.
Translated on 29-10-2026, 9:54.
No new posts Tuning comparison: Chip vs. Powerbox Technical Articles
No new posts Timing belt replacement on a 1.9L PD TDI Troubleshooting & Guides
No new posts Timing belt replacement for transversely mounted PD engine Troubleshooting & Guides
No new posts AFN Chip: What it is and how it works On-Board Diagnostics (OBD)
No new posts Chip Tuning 115 PS - Performance Upgrade Diesel Engine Technology
No new posts TÜV and Chip: What You Need to Know Diesel Engine Technology
No new posts TDI PD 115 PS: Power Loss with Chip Tuning Diesel Engine Technology
