cksIT Blaumann
Joined: 05/22/2004 Posts: 399 Karma: +18 / -0 Location: Riedstadt
28-08-2007, 14:43 Subject: AC Fan Starts Briefly: Troubleshooting Guide |
A colleague has a Leon (1M) with a 150PS TDI engine. Shortly after turning on the air conditioning, the fan runs at full speed for a few seconds. Then it stops spinning (if the engine is cold) and after about a minute, it starts again for a few seconds.
"No idea if this is normal or not?? What controls the fan here? (Could there be a defective temperature sensor...)" Man muss es nicht brauchen, aber man muss es haben!
Translated on 06-10-2026, 13:33.
Joined: 04/12/2002 Posts: 18128 Karma: +803 / -0 Location: St.Gallen 2018 Volkswagen T6
28-08-2007, 15:39 Subject: AC Fan Starts Briefly: Troubleshooting Guide |
My A3 does the same thing, but it's due to a blown fuse for the first fan speed.
Translated on 06-10-2026, 13:34.
Profile PM WWW Garage |
pa-mm6 Blaumann
28-08-2007, 18:48 Subject: AC Fan Starts Briefly: Troubleshooting Guide |
Hi.
"In both fans, the pre-resistors for the first fan speed setting have burned out. This was also the case with my Golf. It happens to every second one!"
Someone should try to badmouth Magneti Marelli again!
I hope I could be of assistance.
P.S. Both fans cost approximately €300 new from the dealer. And it's always both fans that are defective!
"MFG" is an abbreviation for "Mit freundlichen Grüßen," which means "Sincerely" or "Best regards" in English. Audi SQ5 8R Cvub
Translated on 06-10-2026, 13:35.
Profile PM Email |
cksIT Blaumann
28-08-2007, 20:34 Subject: AC Fan Starts Briefly: Troubleshooting Guide |
how?
Do I have to replace both fans??? Can't I just replace the pre-resistors separately?
Is there a way to test and confirm that both are actually defective, or is it just a matter of guesswork? Man muss es nicht brauchen, aber man muss es haben!
Translated on 06-10-2026, 13:36.
pa-mm6 Blaumann
28-08-2007, 20:41 Subject: AC Fan Starts Briefly: Troubleshooting Guide |
Hello.
Unfortunately, the pre-resistors cannot be replaced. The problem is that as soon as one resistor burns out, the second one receives too much current and also burns out very quickly.
The first fan speed usually turns on immediately when the air conditioner is activated.
Translated on 06-10-2026, 13:37.
Profile PM Email |
cksIT Blaumann
28-08-2007, 21:29 Subject: AC Fan Starts Briefly: Troubleshooting Guide |
"That is, he notices that the first stage isn't working and therefore repeatedly triggers the second stage... Is there nothing stored in the error memory? (I need to check myself)." Man muss es nicht brauchen, aber man muss es haben!
pa-mm6 Blaumann
28-08-2007, 21:31 Subject: AC Fan Starts Briefly: Troubleshooting Guide |
HI.
cannot be read out via diagnosis.
Translated on 06-10-2026, 13:38.
Profile PM Email |
renwal Guest
29-08-2007, 15:19 Subject: AC Fan Starts Briefly: Troubleshooting Guide |
You can also fix it yourself; it's been working perfectly for me for the past 3 months.
http://www.ms-kreativ.de/env/download/ReparaturGolfLuefterVorwiderstand.pdf
renwal
cksIT Blaumann
29-08-2007, 15:28 Subject: AC Fan Starts Briefly: Troubleshooting Guide |
"Thank you!"
I'll pass it on and see if it works again  . Man muss es nicht brauchen, aber man muss es haben!
Translated on 06-10-2026, 13:39.
