WarLord wrote: |
Hey, on my Passat (year 1995), the contacts on the ABS control unit are corroded, and since the control unit is attached to the ABS block, it obviously needs to be replaced (or I could replace the contacts, but where can I get those?).
I've done some research and found that the Golf used an ABS module with a part number (3A0 907 379). Now I'm wondering where else this part was used, as I might be able to source parts from those vehicles.
Greetings, WarLord |
Okay, I would start by checking out the junkyards, either in person or by phone.
Normally, you'd expect to find something like that there.
M.
