Ignition Switch Audi A4 (1997) Stuck
Karma: +645 / -0   Thank you, like it!
Post09-09-2007, 10:00    Subject: Ignition Switch Audi A4 (1997) Stuck Quote
Hi.
I hope to find a solution here.
I have an A4 Avant 1.8 from 04/1997, and the ignition switch has been sticking since yesterday.
The key is difficult to insert and remove. Once it's in, it turns relatively easily, but the detents for "ignition on" and "start" are gone or misaligned. I can start the car, but when I release the key, it turns back to the "ignition off" position on its own.
The steering wheel lock isn't working either.
At first, the key wouldn't come out at all; I had to twist it forcefully several times before I could finally pull it out.
What could be broken here? I don't want to replace everything, but only the components that are causing the problem.
Thank you for any helpful answers.
Rüdi.
Translated on 08-10-2026, 4:01.
cksIT
Post09-09-2007, 18:34    Subject: Ignition Switch Audi A4 (1997) Stuck Quote
Just replace the ignition switch. I've had to do that a few times on an A4 before...
Translated on 08-10-2026, 4:03.
Post09-09-2007, 18:41    Subject: Ignition Switch Audi A4 (1997) Stuck Quote
The electrical part?
It's strange that the key is difficult to insert and remove.
Do I need to remove the steering wheel to install this, or can it be done without removing it?
"I'm just asking because the car is currently at a friend's place, and he doesn't have the right tools."
Best regards, Rüdi.
cksIT
dieselschrauber likes this.
Post09-09-2007, 18:47    Subject: Ignition Switch Audi A4 (1997) Stuck Quote
If you can remove the cover around the steering wheel, you don't necessarily have to remove the steering wheel itself. However, that's usually not the case.
The switch protrudes at the top and thus becomes wedged... A change can be accomplished in a few seconds after removing the handlebar.
Simply remove the slotted screws under the paint, then detach the switch. Insert the new switch, tighten the screws, and connect the cables.
Translated on 08-10-2026, 4:05.
No new posts P2006 - Intake manifold control valve stuck closed Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts ATF (Automatic Transmission Fluid) replacement in the aut... Troubleshooting & Guides
No new posts Automatic Transmission Fluid Change 01M Golf III Troubleshooting & Guides
No new posts Ignition Problems: Troubleshooting & Repair On-Board Diagnostics (OBD)
No new posts AGR at 100% - Performance and Optimization On-Board Diagnostics (OBD)
No new posts Ignition switch not working Electrical Systems, Vehicle Electronics, Multimedia
No new posts Ignition Switch Wiring & Glow Plug System Diesel Engine Technology
