Cooler Fan Test: VAG-Com Level 2 Possible?
Post14-09-2007, 10:34    Subject: Cooler Fan Test: VAG-Com Level 2 Possible? Quote
I'm looking for a way to test the radiator fan on a 2002 Golf IV with Climatronic by using a diagnostic tool to set it to level 2.
Background:
Recently, I experienced a situation where, due to traffic congestion after a large event, I was stuck in a very hot car (6 hours at > 28 degrees Celsius). After starting the car, it took about 20 minutes of slow driving before the fan turned on, and it didn't even go up to level 2, which used to happen more often. Level 1 ran continuously as usual. Also, while the air conditioning was noticeable, it didn't cool down the car properly.
Is there a way to do this with VAG-Com, or do I need to bypass it manually?
Translated on 13-10-2026, 5:15.
pa-mm6
Karma: +1 / -1   Thank you, like it!
Post14-09-2007, 21:45    Subject: Cooler Fan Test: VAG-Com Level 2 Possible? Quote
Hi.
should be present in the actuator diagnostics within the engine control unit.
"MFG" is an abbreviation for "mit freundlichen Grüßen," which means "best regards" or "sincerely." It is commonly used in German-language emails and letters.
Audi SQ5 8R Cvub
Translated on 19-10-2026, 11:34.
Back to top Profile PM Email
No new posts A4 8E2/8E5 - Possible various error memory messages Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Is it possible to install a G40 engine without replacing ... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Automatic Transmission: No Rebuild Needed (01K-01F) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts LMM and AGR Off: What Happens? (Under 3000 Miles) Diesel Engine Technology
No new posts A3 8P ESP Stage 2 Tune Diesel Engine Technology
No new posts Radiator Fan Runs at Level 2 - Normal? Diesel Engine Technology
No new posts Fan constantly running at level 2 and very loud. Normal? Diesel Engine Technology
