Turbocharger Boost Control Problem - Golf4 AXR (Solution)
Post01-10-2007, 15:38    Subject: Turbocharger Boost Control Problem - Golf4 AXR Quote
In the Golf 4 with an AXR engine, a leak in the vacuum control valve for the EGR cooling system can result in insufficient vacuum being available for the turbocharger pressure regulation.
"Check using the basic settings mode, e.g., with VAG-COM or VCDS. The difference between the "on" and "off" states of the actuator for turbocharger boost control should be approximately 150 mbar."
Otherwise, check the vacuum system for leaks, test the vacuum pump for proper function, and verify the functionality of the adjustment mechanism on the turbocharger.
Translated on 16-08-2026, 4:00.
Ratings - Turbocharger Boost Control Problem - Golf4 AXR
Average rating: 5.00 - worst rating: 5 - best rating: 5 - number of ratings: 1 - View ratings
No new posts Audi A3: Faulty Fan Repair & Service Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts A4/A6 Doku: Faulty Fan Control System Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document A6 4B from 9/2001, window opening sealing faulty Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts EDS System Error: Troubleshooting & Fixes Diesel Engine Technology
No new posts Outdoor Temperature Display Malfunction! Diesel Engine Technology
No new posts Audi A6 Error 01117: Load Signal Fault Diesel Engine Technology
No new posts Golf 4, 2000, APF, Secondary air pump - Faulty shift signal Gasoline Engine Technology
