VAG-COM Datei, hilfe bei der Auswertung | Posts 16+
Go to page: Previous  1, 2
Post13-10-2007, 16:35    Subject: Quote
Hi Jochen,
Ein grosses Probelm ist halt die Bestimmung der Getriebeverluste, die, wenn allein über die Geschwindigkeiten bestimmt werden soll, auf öffentlichen Strassen schnell an ihre Grenzen gelangt.
Not really. While I'm lucky enough to always be within 5 km of a suitable "measuring track," the program isn't stupid and uses quite clever interpolation techniques. So, you don't have to let it run for an eternity.
As with any testing procedure, the devil is in the details; the person performing the measurement should understand what they are doing.
Ultimately, it often comes down to small details like whether someone simply reduces the throttle instead of disengaging the clutch when measuring drawbar power.
Similarly with performance correction according to DIN standards. If someone doesn't understand what it does or whether it's even appropriate in a specific case, it's better to leave it at the standard values rather than trying to "improve" things and potentially making them worse.
Translated on 13-07-2026, 0:01.
Post13-10-2007, 17:13    Subject: Quote
Jochen_145 wrote:
The complexity of performance measurement without a dynamometer is illustrated by a test conducted in the automotive magazine "Abendteuer Auto."
Here, the performance box from GPS measurement specialist racelogic clearly failed to deliver.
Die 4 Messungen der Leistungen eines BMW M3 differerierten von 88 (!) bis 286PS...
Hi Jochen,
Without knowing the specific article, I would assume that such inconsistencies are due to significant user errors (see Rainer's response) and/or GPS measurement errors.
Is this measurement experiment available to view online anywhere?
Translated on 13-07-2026, 0:03.
Jochen_145
Post13-10-2007, 19:47    Subject: Quote
Der Teufel steckt wie bei jeder Prüfstandsmessung im Detail, derjenige der die Messung macht sollte verstanden haben was er tut.
Hello Rainer,
That's exactly the point.
For example, one should not choose a 'runway' section that includes an uphill and downhill slope with an undefined gradient.
By carefully considering all the relevant parameters, it is possible to achieve sufficiently good results with a draft calculation tool.
@Ulf
You can view the performance box test here:
http://www.kabeleins.de/auto/videos/sonstiges/artikel/12170/
Racelogic's products are fundamentally very useful, especially for open test tracks or proving grounds. However, the V-Box models I through III also find applications in a completely different price range.
Best regards, Jochen.
Translated on 13-07-2026, 0:05.
No new posts Log Analysis: Audi A6 2.5 BDG (3-8-11) On-Board Diagnostics (OBD)
No new posts Log File Analysis: Insights & Optimization On-Board Diagnostics (OBD)
No new posts TDI Engine Codes: Final Statistics & Analysis Diesel Engine Technology
No new posts Analysis of a performance diagram... Diesel Engine Technology
