Connection Diagram for Injection Start Valve (VW Engine 1Y)
New Topic Reply 🔗 🖨 Dieselschrauber - Index » On-Board Diagnostics (OBD)
Dieselfreak
Post29-10-2007, 10:08    Subject: Connection Diagram for Injection Start Valve (VW Engine 1Y) Quote
I installed the identical fuel pump from my Seat (same engine 1Y) into my Golf 3 Diesel. Since then, I've been experiencing rough running and misfiring. Could a misconnected valve for fuel injection timing be the cause? The colors of the two cables on the Seat pump are different from those on the VW pump. How do I test the correct polarity?
Greetings
Dieselfreak
s.feichtinger@kreis-herford.de
No new posts AJM Motor - Motor klappert, Leistungsmangel, Schwarzrauch Fehler und Dokumentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Übersicht AFB-Motor Fehler und Dokumentation (Audi, VW, Seat/Cupra, Skoda)
No new posts 2.0 TDI Motor Kühlmittelverlust Fehler und Dokumentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Fehler 4422 - Ventil für Einspritzbeginn - SELTSAM! Diesel Motorentechnik
No new posts Motor AFB: Einspritzbeginn Upload
No new posts AFB Motor: Einspritzbeginn verstellen On-Board-Diagnose (OBD)
No new posts Wastegate Ventil bei 1z Motor Diesel Motorentechnik
