Golf 3 TDI AFN: Troubleshooting Performance Issues
seagate
Post19-05-2002, 17:57    Subject: Golf 3 TDI AFN: Troubleshooting Performance Issues Quote
Hello everyone!!!
First of all, I would like to thank everyone who helped me with my previous problem, but unfortunately, my machine still isn't working properly.
After installing the AT machine, I had the pump checked and adjusted by a VAG workshop, but the machine still isn't producing any power. At the same time, I had the error memory read out, but the guys at VW couldn't make sense of the errors because the car has been chipped by the company ProSport, and they saw several implausible signals, including from the mass airflow sensor (MAF). Could that be a problem?
Please provide the text you would like me to translate from German to English. I will provide the translation as quickly as possible.
Translated on 16-10-2026, 4:46.
Post20-05-2002, 8:43    Subject: Error Codes: What They Mean & How to Fix Quote
Hi.
I had the error memory read at the same time, but the guys at VW couldn't do anything with the errors because the car had been chipped by the company ProSport, and there were several implausible signals to be seen.
That is, of course, a nice salad icon_sad.gif.
I'm not sure to what extent chip tuning can interfere with the error memory function... Are you sure they're not just trying to trick you, the "unwanted" chip tuner?
"Nonsense" entries in the error memory usually indicate a faulty relay 109, which is often also noticeable through jerking and similar symptoms, and can be quickly resolved by replacing the relay.
Otherwise, a faulty mass airflow sensor is a common cause of power loss.
But even VTG (a German company) can sometimes cause real trouble.
In my opinion, every driver of an aftermarket turbocharger (AFN) should accept that a boost pressure gauge should be considered a "mandatory" piece of equipment on board, allowing them to monitor the function of the turbocharging system, especially when experiencing occasional power loss.
Translated on 16-10-2026, 4:48.
Michael II
Post20-05-2002, 9:06    Subject: Golf 3 TDI AFN: Troubleshooting Performance Issues Quote
Please share the error codes. Maybe someone here can help you.
Tschüss
Michael II
Translated on 16-10-2026, 4:49.
seagate
Post20-05-2002, 10:28    Subject: Golf 3 TDI AFN: Troubleshooting Performance Issues Quote
hi everyone
Okay, thanks for the tip about the LMM, but it costs a few euros too much to just replace and test it. And, unfortunately, they didn't give me the diagnostic code.
I heard that the LMM can also be cleaned.
In another post, I read about problems with aftermarket air filters (K&N, etc.), and I have a JR replacement filter. Could it be that the mass airflow sensor (MAF) is just dirty? And how can I clean it without damaging it?
Translated on 16-10-2026, 4:50.
Post20-05-2002, 13:07    Subject: Clean LMM: How to Clean Your LMM Quote
. . . it says it right there:
Okay, I understand. Please provide the German text you want me to translate into English. I will only provide the translation.
Translated on 16-10-2026, 4:51.
seagate
Post20-05-2002, 16:20    Subject: Golf 3 TDI AFN: Troubleshooting Performance Issues Quote
Hi and thank you.
Thank you for the link!
I have now also learned that it is possible that the valve timing is not correct, and that this could also be a problem. icon_redface.gif
I'll check those now.
Seagate.
Translated on 16-10-2026, 4:52.
No new posts Golf 4 Fault Code Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf IV 1.9 TDI AXR - Stutters under load Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 5 1.4 BUD Misfire 2. Cylinder Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 3 TDI 81kW power issues Diesel Engine Technology
No new posts Golf 6 1.4 TSI CAXA - Power issues, cold start problems Gasoline Engine Technology
No new posts Performance issues with TDI 96 kw Diesel Engine Technology
No new posts TDI Performance Issues: 1.9 TDI PD 85kW Diesel Engine Technology
