Nozzle Heater Check: Golf 4 Diagnostics
pa-mm6
Karma: +1 / -1   Thank you, like it!
Post27-12-2007, 19:49    Subject: Nozzle Heater Check: Golf 4 Diagnostics Quote
Hello.
Is it possible to read the windshield washer nozzles using the diagnostic system in a Golf 4? Also, are these nozzles logged in the error memory if they malfunction, similar to the side mirror heating? I once had a defective side mirror glass that was displayed in the error memory.
A few days ago, the nozzles froze, so I'd like to be on the safe side.
"MFG" is an abbreviation for "mit freundlichen Grüßen," which means "best regards" or "sincerely." It is commonly used in German-language emails and letters.
Audi SQ5 8R Cvub
Translated on 23-10-2026, 14:12.
Back to top Profile PM Email
vagtuning
Post27-12-2007, 23:02    Subject: Nozzle Heater Check: Golf 4 Diagnostics Quote
No, there are definitely still parts that are not diagnosable.
Translated on 23-10-2026, 14:13.
pa-mm6
Post28-12-2007, 6:51    Subject: Nozzle Heater Check: Golf 4 Diagnostics Quote
Too bad icon_sad.gif, I thought it might be related to the mirror heating. Well, I guess I'll have to get out the ohmmeter.
Thank you for the response.
Audi SQ5 8R Cvub
No new posts DIY OBD Adapter: Build Your Own Diagnostic Tool Troubleshooting & Guides
No new posts Golf 1J: GRA Failure When Turn Signal Is On Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Eberspächer Heater Diagnostics: Troubleshooting Guide Troubleshooting & Guides
No new posts Is it possible to perform a diagnosis on a Peugeot 406? On-Board Diagnostics (OBD)
No new posts Golf 6 BiFuel: Gas ECU Diagnostics On-Board Diagnostics (OBD)
No new posts Golf 4 TDI: Read Oil Temperature via Diagnostics On-Board Diagnostics (OBD)
No new posts Golf IV/Audi A4 Diagnostic Interface On-Board Diagnostics (OBD)
