Hi Thomas,
...that doesn't sound good
. If the adapter rotates along with it, then either the pressure line
will twist and potentially tear, or the contact surface between the line and the adapter will be damaged. I once had this problem with an injector line
-> that's why I always hold the adapter in place when loosening such lines, especially if you feel that the loosening torque is very high.
Do you have two open-end wrenches from Hazet? With enough force and leverage, the Hazet wrenches should be able to loosen the connection
. I can only recommend Hazet tools (and Gedore as well) again and again... these tools are a lifesaver, especially when dealing with connections like these
But don't worry about it... it's a rule of thumb for me that something extra always breaks when I do things like that
but be careful that no chips get into the turbo
Best regards, Christian.
