Boost Pressure Logs - German Cars
New Topic Reply 🔗 ⭐ 🖨 Dieselschrauber - Index » Upload
servusssss
Post12-01-2008, 15:29    Subject: Boost Pressure Logs - German Cars Quote
"Weak starting torque with BRD."
Leaves on a flat road surface. Outside temperature is approximately 0 degrees Celsius.
Nach Update9888.xls
 Log mit SW 9888 im 4ten Gang bergauf
 File name:  Nach Update9888.xls
 File size:  28 KB
 Downloaded:  463 times
Log neu1.xls
 Log mit neuem LMM
Log mit neuem LMM
 File name:  Log neu1.xls
 File size:  22.5 KB
 Downloaded:  411 times
LOG_MWB1_4Leerlauf_konv.csv.xls
 MWB 1&4 im Leerlauf 4°C Luftemp.
 File name:  LOG_MWB1_4Leerlauf_konv.csv.xls
 File size:  37.5 KB
 Downloaded:  421 times
LOGMWB74_75_konv.xls
 Teil & Volllast MWB mit Lamda
Jetzt mit Spaltenbezeichung
 File name:  LOGMWB74_75_konv.xls
 File size:  87 KB
 Downloaded:  414 times
Leistung.xls
 File name:  Leistung.xls
 File size:  38.5 KB
 Downloaded:  433 times
LOG_MWB3_Grundeinstellung.xls
 MWB3 Grundeinstellung
 File name:  LOG_MWB3_Grundeinstellung.xls
 File size:  47.5 KB
 Downloaded:  368 times
LOG_leerlauf_MWB3_konv.xls
 MWB3 im Leerlauf
MWB3 im Leerlauf
 File name:  LOG_leerlauf_MWB3_konv.xls
 File size:  58.5 KB
 Downloaded:  357 times
LOG2.xls
 File name:  LOG2.xls
 File size:  21 KB
 Downloaded:  393 times
LOG1.xls
 File name:  LOG1.xls
 File size:  19.5 KB
 Downloaded:  464 times
Translated on 08-09-2026, 0:48.
No new posts Power Loss: Air Mass/Boost/Timing OK? Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Bora AJM Turbo Pressure: Requesting MWB 011 Data On-Board Diagnostics (OBD)
No new posts Logs 3-8-11, AVB 74 kW Upload
No new posts Logs for 2.0 TDI 8PA - Engine Code: BKD with DSG; Control... Upload
No new posts Logs 2.0 TDI 8P DPF - Engine Code: BMM Upload
