Is it possible that the problem doesn't occur as frequently with a functional AGR system because the higher temperature (due to the mixing of air with hot exhaust gases) reduces its occurrence?
Of course, not at an average of 125, but rather in the partial load range due to faster heating?
Gruß, der Teileklaus
Fiat 500, Einkaufswagen
Is it possible that with functional EGR, the problem doesn't occur as frequently due to the higher temperature (because of the air mixed with hot exhaust gases)?
Of course, not at an average of 125, but in the partial load range due to faster heating?
However, the AGR (Agricultural Support Reform) only comes into effect after the LLK (Landwirtschaftliche Direktzahlungen - Agricultural Direct Payments).
