tim27 wrote: |
An oil cooler has to be installed, I would say, or a larger radiator?
because that also helps to lower the temperature, which is quite simple. |
Hi tim27!
The simplest thing to do is to remove the "10 cent tuning" again.
The chip already optimizes the injection timing, and adding 10 cents' worth of fuel is simply overkill. The supposedly higher efficiency would actually result in less, not more, waste heat entering the engine/engine oil! However, because you have a higher oil temperature, your engine doesn't have proper combustion and reduced efficiency. The premature injection timing significantly increases the stress on the pistons, crankshaft, etc. Your current setup might not be sustainable for full throttle operation in the long run.
If you want more performance than what chip tuning offers, I would suggest setting the "10 Cent Tuning" very conservatively, or better yet, ask the tuner about higher performance levels for the chip. While an oil cooler will lower the oil temperature, the engine's overall stress remains the same.
For more information on the large language model, please refer to Rainer's report.
Uwe.
Kundenservice bedeutet bei Audi, die Kunden so schnell über den Tisch zu ziehen, daß sie die Reibungswärme als Nestwärme empfinden!
