Remove Door Lock Cylinder Without Key
Rudi
Post28-01-2008, 11:50    Subject: Remove Door Lock Cylinder Without Key Quote
Hi!
Unfortunately, my Pampersbomber needs a new door.
I also got that door from the recycling center.
The problem now is that the lock cylinder is still in the door, and (obviously)...
Whether the handle or the locking cylinder are damaged during removal is irrelevant.
(as long as the door itself isn't damaged), because the parts of the old door are still there.
Okay.
Has anyone ever installed something like this before?
Large, forged screwdriver and brute force?
Rudi
Translated on 13-10-2026, 8:44.
cksIT
Post28-01-2008, 11:57    Subject: Remove Door Lock Cylinder Without Key Quote
As far as I remember, it wasn't a problem with the G3. Just remove the Torx screw inside, push the handle forward, and swing it out.
Translated on 13-10-2026, 8:45.
Rudi
Post28-01-2008, 15:19    Subject: Remove Door Lock Cylinder Without Key Quote
'Actually,' you need to turn the key 90 degrees for the locking mechanism to disengage.
Since one half of the locking mechanism is made of plastic, a firm pull icon_wink.gif will also work.
Rudi
No new posts Removing and cleaning a diesel particulate filter (DPF) Troubleshooting & Guides
No new posts Passat 3BG AVB - Remove bearing from Visco fan Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Power loss without soot Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts 3BG Door Problems: Handle and Lock Cylinder Upload
No new posts Key and WFS Coding: A Practical Guide On-Board Diagnostics (OBD)
No new posts Programming keys Diesel Engine Technology
No new posts Water in the lock... Transmission, Chassis, Body & Interior
