Problem Pumpe-Düse AXR | Posts 16+
Go to page: Previous  1, 2
Post14-08-2007, 11:16    Subject: Quote
Poison doesn't exist in isolation. If you work carefully, you can reuse the material. Otherwise, there's sealant available. Depending on the car, you may need to remove/disassemble the EGR unit; otherwise, you won't be able to get the cover off. Replacing the rail is quick. Disconnect the connectors on the PD injectors; they are quite "tight." Loosen the two screws from the outside of the round connector and carefully pull the component out. Reassemble in reverse order, and it's done...
Translated on 23-08-2026, 19:10.
mserge
Post14-08-2007, 11:26    Subject: Quote
Okay, I had to loosen the AGR unit and move it slightly to the side in order to reach one of the screws on the cover. It's not a major job overall, but removing the cover itself is quite fiddly. The timing belt cover also needs to be removed, but that came off easily as it was only held in place by two clips.
To remove the "rail," you need to use a screwdriver or something similar to slightly bend the springs inward, otherwise the part will get stuck, but you'll see that when you get to that point.
You don't need to replace the gasket; I cleaned it a bit, put it back in place (with the lid), and it sealed properly again.
@Mike3BD:
You can definitely do this yourself; the icon_biggrin.gif doesn't necessarily have to be involved. It's just some basic mechanical work, and it doesn't require any special knowledge or materials. However, be careful and work very meticulously and cleanly, otherwise dirt might get in.
neuer Turbo bei 200.000km
neue ESP bei 216.000km
verkauft mit 225000tkm
Clio 2 RS 170 PS BJ2003
Translated on 23-08-2026, 19:12.
pa-mm6
Karma: +1 / -1   Thank you, like it!
Post02-02-2008, 15:57    Subject: Quote
HI.
My Golf is also scheduled for service on Monday, and I'm having the same problems with the wiring harness. I could save the old wiring harness and maybe test it later. In my case, the error always occurred in cylinder 3. I'm going to take a look at the connector for injector element 3.
Hopefully everything will work perfectly on Monday.
Is there perhaps a repair manual or something similar available?
"MFG" stands for "Mit freundlichen Grüßen," which translates to "Sincerely" or "Best regards" in English. It is a common way to end a formal letter or email.
Audi SQ5 8R Cvub
Translated on 23-08-2026, 19:13.
Back to top Profile PM Email
pa-mm6
Post04-02-2008, 20:33    Subject: Quote
Okay, the wiring harness has been replaced; it's actually not a big deal.
I've taken some photos for you here; hopefully they will be helpful. Whether the issue has been resolved will become clear in the next few days. I'll keep you updated.
 Der neue Kabelbaum
 File size:  2.5 MB
 Viewed:  49580 times
 Die Steckverbindung auf der rechten Seite des Zylinderkopfes
 File size:  1.88 MB
 Viewed:  24905 times
 Hier sieht man den Stecker und die Buchse. Der Stecker sitzt meist recht fest. Mit ein wenig Gefühl bekommt man ihn raus.
 File size:  1.8 MB
 Viewed:  18245 times
 Hier kann man die Stecker und den Kabelbaum recht gut erkennen.
 File size:  2.55 MB
 Viewed:  33997 times
 Der Motor ohne Ventildeckel, beim abbauen muss beim ARL die Agr Einheit etwas gelockert werden, damit man an die Schraube links oben kommt.
 File size:  2.37 MB
 Viewed:  25119 times
Audi SQ5 8R Cvub
Translated on 23-08-2026, 19:15.
mserge
Post07-02-2008, 11:38    Subject: Quote
When working on the AXR (likely referring to an exhaust manifold), you also need to loosen and move the AGR (Exhaust Gas Recirculation) valve out of the way. You can then clean it thoroughly before reassembling everything.
No new posts Replacing injector nozzles in common rail injectors Troubleshooting & Guides
No new posts Adjusting timing and PD element for common rail diesel en... Troubleshooting & Guides
No new posts Timing Chain Wear: Inspection & Repair Guide Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Pump-nozzle Diesel Engine Technology
No new posts AJM Injector Pump GRA Calibration Diesel Engine Technology
No new posts Pumpe-Düse vs. Common Rail: Differences Explained Diesel Engine Technology
No new posts Injector Nozzles for 2.0 TDI 16V Engine Diesel Engine Technology
