Combine two Webasto's into one?
New Topic Reply 🔗 🖨 Dieselschrauber - Index » On-Board Diagnostics (OBD)
grünling
Post17-02-2008, 15:30    Subject: Combine two Webasto's into one? Quote
Hello everyone,
I'm new to this forum and would like to take advantage of this opportunity to ask a question.
My previous Webasto Top C (Diesel) has broken down. A friend of mine used a diagnostic tool to read the following error message:
NAK: Unknown negative acknowledgement code 0x45 or solenoid failure code 90
What do these error codes mean?
I would like to convert two Webasto (diesel) units into one, and I am now wondering if these units can be interchanged with each other (e.g., with a Webasto Top C/Z or E).
Do the differences generally only lie in the control software (i.e., only replacing the control unit)? Or are there also different types of glow plugs and combustion chambers, etc.?
I also read that there are TT models with 4.2 kW or 5.0 kW.
I would appreciate a response.
Best regards from the Lusatia region.
Greenling
No new posts Diagnose nachgerüsteter Webasto Standheizungen Fehlersuche & Anleitungen
No new posts Einspritzdüsen tauschen (selber machen / eine oder alle) Diesel Motorentechnik
No new posts OM 948.961 fit machen für den Osten Diesel Motorentechnik
No new posts Bremsleitungen Golf III neu machen Getriebe, Fahrwerk, Karosserie und Innenraum
No new posts Düsentuning, wie die Amis das so machen. Diesel Motorentechnik
