Golf 1J: Rear Clicking Noise - Diagnosis & Repair (Solution)
Michael II
Post05-03-2003, 14:50    Subject: Golf 1J: Rear Clicking Noise - Diagnosis & Repair Quote
In the affected vehicles, cracking noises may occur in the area of the rear wheel arches.
Cause:
The issue arises when the rear shock absorbers are not sufficiently decoupled from each other due to the upper damper bearings.
Solution:
In case of a complaint, swap the upper damper bearings with each other. Once the knocking noise shifts to the opposite side of the vehicle, a new, acoustically improved damper bearing (part number 1J0 513 353 D) must be installed.
This damper bearing is standard equipment on certain vehicle configurations.
Vehicles with the PR numbers 1JC, 1JH, 1JG, UB3, and UA9 are equipped as standard with the improved damper bearing (index D) since December 1999 (for Golf and Bora models) or June 2000 (for Beetle models).
Tschüss
Michael II
Translated on 07-08-2026, 14:15.
Ratings - Golf 1J: Rear Clicking Noise - Diagnosis & Repair
No new posts Golf 1J Doku: Clicking Noises (Up to KW 16/98) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 1J Speaker Crackling: Diagnosis & Repair Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 1J Repair: Rear Hatch Lock Problems Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Rear Bumper VW Golf 4 / IV Transmission, Chassis, Body & Interior
No new posts Golf 5 2.0 TDI 4-Motion rear brake caliper Transmission, Chassis, Body & Interior
No new posts Rear Brake Wear: VW Golf IV Variant AXR Transmission, Chassis, Body & Interior
No new posts Rear Window Regulator Coding VW Golf IV (1999) On-Board Diagnostics (OBD)
