"This past weekend, I cleaned my potentiometer and recorded the voltage readings beforehand. The reading with the motor off (MWB 001) was 0.700V, and the range for MWB 019 was 0.700-4.440V. After cleaning, I reset the sensor to 0.700V, but now when I read MWB 019, the maximum reading is only 4.380V. Mechanically, everything feels smooth and there are no sticking points."
Why is my minimum voltage reading not at 0.740V like most others here?
What are the voltage readings from your potentiometer? I want to collect those values in order to determine if there might be an incorrect adjustment of the potentiometer.
"Thank you!"
Best regards, Reuselkopp. Golf 4 Variant Modell 05, ASZ mit 330000, ERF Getriebe, mit Zwangskorken, Softwareanpassung von Alex Günther
Golf 3 Variant Modell 98, AFN mit 281000km, ASD Getriebe, VNT15 mit großer Dose, ansonsten alles Original / verkauft
Translated on 24-08-2026, 16:03.
