Golf 1J: GRA Failure When Turn Signal Is On (Solution)
Michael II
Post06-03-2003, 9:01    Subject: Golf 1J: GRA Failure When Turn Signal Is On Quote
The speed control system fails when the turn signal is activated or cannot be turned on.
Cause:
During the assembly of the lower steering column cover, the circuit board film on the steering stalk switch may be damaged. This can cause the following errors:
The speed control system fails when the indicator light flashes.
The speed control system cannot be activated.
Solution:
Replace the steering column switches.
TschĂźss
Michael II
Translated on 24-08-2026, 19:22.
Ratings - Golf 1J: GRA Failure When Turn Signal Is On
No new posts Audi A6 4B: Faulty TV Tuner - Repair Guide Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts A4 Documentary: Fuel Drop After Reserve (1999) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Documentary: DPF (Diesel Particulate Filter) Problems in ... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts RPM decreases on the G4 AXR. Diesel Engine Technology
No new posts Golf 3 Headlight Failure: Why Does It Happen? Diesel Engine Technology
No new posts MotorstĂśrung (rotes Blinken) aber kein Fehler gespeichert Diesel Engine Technology
No new posts Alhambra/7M - KI occasionally fails Electrical Systems, Vehicle Electronics, Multimedia
