Golf 1J Radio Issues: Troubleshooting Guide (KW 43/98) (Solution)
Michael II
Post06-03-2003, 12:03    Subject: Golf 1J Radio Issues: Troubleshooting Guide (KW 43/98) Quote
Antenna for radio, telephone, and navigation systems.
Poor radio reception.
Poor MW reception, significantly worse FM reception.
Cause:
Due to water ingress into the plastic housing of the antenna amplifier, corrosion occurs, which increases the contact resistance between the contact spring on the circuit board and the threaded bushing.
Solution:
Adjust the medium wave radio frequency. Touch the antenna rod in the area of its thickening. Gently pull or push the antenna rod. If the reception changes significantly, the amplifier is defective and must be replaced.
"Note:"
The exam should be conducted outdoors.
Tschüss
Michael II
Translated on 30-09-2026, 15:16.
Ratings - Golf 1J Radio Issues: Troubleshooting Guide (KW 43/98)
No new posts Golf 1J Doku: Clicking Noises (Up to KW 16/98) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 1J: Rear Clicking Noise - Diagnosis & Repair Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 1J Speaker Crackling: Diagnosis & Repair Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 3 GTI TDI: Bad Starting Issues & Fixes Diesel Engine Technology
No new posts Passat TDI: Cold Start Problems & Solutions Diesel Engine Technology
No new posts Engine Stalling: Is Bad Diesel the Cause? Diesel Engine Technology
No new posts Schlechter kalt start mit viel Rauch Diesel Engine Technology
