Injector Nozzles for 2.0 TDI 16V Engine
Post12-10-2007, 20:46    Subject: Injector Nozzles for 2.0 TDI 16V Engine Quote
Does anyone know of a source for larger injector nozzles for the pump-injector elements used in 2.0L 16V engines?
Translated on 02-09-2026, 17:45.
mullemaus
Post12-10-2007, 23:08    Subject: Injector Nozzles for 2.0 TDI 16V Engine Quote
Hi Rainer.
I couldn't find information about the 125KW engines quickly. The 103KW engines have the PDE-P2/80/475S403 installed, and are available with both automatic and manual transmissions. For which specific vehicle are you looking? The 103KW or the 'bigger' one? icon_wink.gif
Translated on 02-09-2026, 17:46.
Post13-10-2007, 10:02    Subject: Injector Nozzles for 2.0 TDI 16V Engine Quote
Hi Mulle,
The 103kW system uses Bosch components icon_smile.gif. Unfortunately, the well-known manufacturer of 2V PD injectors doesn't offer anything suitable, and based on my rough calculations, I can only achieve a maximum of about 200 horsepower with the original injectors, without extreme injection angles and exhaust temperatures, which I consider to be a bit too low. Please note, this refers to engines with 4V cylinder heads... there might already be a solution for the 2V models.
Translated on 02-09-2026, 17:47.
Olaf
Post13-10-2007, 22:10    Subject: Injector Nozzles for 2.0 TDI 16V Engine Quote
Unfortunately, I can't provide any further assistance. I'm just curious whether the 170 hp version of the engine is so different that you can't use parts from it. Isn't it also a 4-valve engine? Or are the PD (piezo injector) units the same for both engines?
Thank you for the information.
Olaf.
Translated on 02-09-2026, 17:48.
Back to top Profile PM Email
mullemaus
Post14-10-2007, 21:11    Subject: Injector Nozzles for 2.0 TDI 16V Engine Quote
Unfortunately, I still can't help further. I'm just curious if the 170 HP version of the engine is so different that you can't use parts from that version? Isn't that also a 4-valve engine?! Or are the PD units the same on both engines?
Olaf
I haven't been able to gather any information yet icon_wink.gif.
Translated on 02-09-2026, 17:49.
majesty78
Post07-03-2008, 8:51    Subject: Injector Nozzles for 2.0 TDI 16V Engine Quote
Hello Rainer!
Is this topic still relevant to you?
I should soon have access to a supplier that offers these types of nozzle tips!
Best regards, AlexXx
Translated on 02-09-2026, 17:50.
No new posts Replacing injector nozzles in common rail injectors Troubleshooting & Guides
No new posts Adjusting timing and PD element for common rail diesel en... Troubleshooting & Guides
No new posts Timing Chain Wear: Inspection & Repair Guide Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts FRP Injectors: Buy, Repair & More. Diesel Engine Technology
No new posts Pump-nozzle Diesel Engine Technology
No new posts AJM Injector Pump GRA Calibration Diesel Engine Technology
No new posts Pump Nozzle Problem AXR - Common Issue? Diesel Engine Technology
