Golf 1J: Auto Volume Changes Automatically (Solution)
Michael II
Post06-03-2003, 12:06    Subject: Golf 1J: Auto Volume Changes Automatically Quote
The phone's volume is changing on its own.
Vehicle with radio navigation system.
Cause:
The phone volume, which is set in the volume settings, is occasionally reset to zero for reasons that are currently unknown. As a result, incoming calls are no longer detected.
Solution:
A separate speaker is required for telephone playback (accessory). The audio signal from the interface box (T18/7 and T18/16) must be connected directly to this speaker. The previous connection to the speaker switching relay is no longer used. When a call is received, the radio is muted via T8/2, and the voice playback occurs through the separate speaker. The telephone volume can only be adjusted on the mobile phone. Replacing the radio and/or telephone components will not make a difference!
Tschüss
Michael II
Translated on 05-10-2026, 13:09.
Ratings - Golf 1J: Auto Volume Changes Automatically
No new posts Golf 1J documentary: Air vent nozzle cannot be closed Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku A3 8L, horn honks by itself Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi A3 8P: Floor Covering Detaching Problem Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Fixing Errors: Does It Resolve Itself? On-Board Diagnostics (OBD)
No new posts Siemens PPD: Self-Cleaning or Not? Diesel Engine Technology
No new posts Machining a cylinder head for a VW 1.6TD (Golf) - DIY Diesel Engine Technology
No new posts 1Z Spritzbeginn verstellt!? Diesel Engine Technology
