Golf 1J Radiator Leak: Repair Guide & Info (Solution)
Michael II
Post07-03-2003, 10:56    Subject: Golf 1J Radiator Leak: Repair Guide & Info Quote
Coolant leak at the radiator, in the area of the side water tanks.
Cause:
In rare cases, due to insufficient sealing pressure between the radiator and the side water tanks, coolant leakage may occur, especially when tolerances are unfavorable.
Solution:
Perform a leak test of the cooling system. If a coolant leak is detected in the area of the side water tanks, the cooler must be replaced.
Tschüss
Michael II
Translated on 15-09-2026, 19:38.
Ratings - Golf 1J Radiator Leak: Repair Guide & Info
No new posts Golf 1J Headlight Washer Pump Leak - Repair Guide Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document A6 4B, Fog lights leaking Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Transporter 7D: Leaky Heater Valve - Documentary Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
This topic is locked, you cannot edit or reply. Leaky Golf 3 Radiator: Other Causes & Fixes Diesel Engine Technology
No new posts Golf 3 '97 Schiebedach-Dichtung undicht!? Transmission, Chassis, Body & Interior
No new posts AGR Coolers in Action Upload
No new posts Cooler Replacement: How to Change Your Cooler Diesel Engine Technology
