Golf 1J: Engine Knocking Noise - Diagnosis & Repair (Solution)
Michael II
Post07-03-2003, 11:08    Subject: Golf 1J: Engine Knocking Noise - Diagnosis & Repair Quote
Transmission assembly 02J.
Tapping noises when idling/at standstill.
Rattling/clattering noises coming from the transmission when the vehicle is stationary, the engine is idling, and the engine is cold.
The noises disappear when the 5th gear is engaged by the hand lever and when the clutch pedal is pressed.
Cause:
Sounds ("clattering") from the synchronizer ring, 5th gear.
Vibrations generated by the engine are transmitted through the transmission input shaft/drive shaft to the transmission, causing vibrations in the gears that are not currently engaged.
Unfavorable tolerances in the transmission, dual-mass flywheel, and clutch disc exacerbate this phenomenon. Noises are usually louder in cold engines.
Serial solution:
Reinforced locking plate spring in the synchronizer hub for 5th gear, starting from transmission production date 28111.
In cases of persistent complaints, the product support team should be notified.
TschĂźss
Michael II
Translated on 26-08-2026, 1:01.
Ratings - Golf 1J: Engine Knocking Noise - Diagnosis & Repair
No new posts Golf 1J: Sunroof Rattle Noise - Diagnosis & Repair Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document: Golf 1J, from week 48/98, Clattering noise afte... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts MKB, AHW, AKQ, APE: Documenting Clicking Noises Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 4, high idle speed Gasoline Engine Technology
No new posts Golf IV TDI Misfire: Troubleshooting & Repair Diesel Engine Technology
No new posts New Golf TDI PD 74Kw -> Idle speed Diesel Engine Technology
No new posts Unruhiger Motorlauf im Leerlauf, Golf Tdi90, AHU Diesel Engine Technology
