Boost Pressure, VTG, Check Valve: I Don't Get It
Simusas
Post27-03-2008, 20:59    Subject: Boost Pressure, VTG, Check Valve: I Don't Get It Quote
Hello and good evening.
I still have (see also https://community.dieselschrauber.org/en/viewtopic.php?t=17411) the problem that my Golf IV (110 HP TDI, manufactured in 7/9icon_cool.gif goes into limp mode. The reason for this is a constantly too-high boost pressure.
After checking the system with VCDS and having already inspected the vacuum hoses several times, I decided to buy completely new hoses.
I installed it today and I'm off to drive. Everything is actually working perfectly, except that above 3800 RPM, the boost pressure gets a little too high (about 0.3 bar).
I then wanted to check if the VTG (variable turbine geometry) was still functioning correctly (in its default setting), but nothing changed. The reason for this was that there was no vacuum reaching the turbo.
Okay, so I reversed the check valve, and I was right back to the same problem. Even at 1500 RPM, there's way too much boost pressure, and it doesn't regulate itself after releasing the throttle (or it regulates very, very slowly).
However, VTG had adjusted its basic position in the meantime.
Why is it that my boost pressure is building up perfectly (target pressure equals actual pressure), even though I don't see any adjustments and don't feel any vacuum?
Actually, it should behave as if it's in a degraded mode, even though it's accelerating perfectly.
I am now completely confused and hope someone can help me.
Thank you in advance, and have a pleasant evening.
Sven.
Translated on 06-10-2026, 14:00.
mserge
Post28-03-2008, 9:47    Subject: Boost Pressure, VTG, Check Valve: I Don't Get It Quote
"Hi, I had something similar once. There's a vacuum hose that runs behind the diesel filter to the turbocharger. Check it to see if it's been pinched by the diesel filter. I had a service done, and after that, the engine was only producing 50 horsepower! Then we checked the hoses, and the variable geometry turbo (VTG) couldn't move anymore (due to the vacuum). After we pulled the filter out a bit and rerouted the hose, everything worked as it should again."
neuer Turbo bei 200.000km
neue ESP bei 216.000km
verkauft mit 225000tkm
Clio 2 RS 170 PS BJ2003
Translated on 06-10-2026, 14:02.
Simusas
Post28-03-2008, 10:21    Subject: Boost Pressure, VTG, Check Valve: I Don't Get It Quote
As I understand it, you're referring to the hose that runs directly from the boost pressure control valve to the pressure sensor on the turbo. I replaced that hose, among other things, yesterday. And as I said, what's strange is that I haven't experienced any noticeable loss of power, despite everything. I'll try driving without the hose later. There was a topic where someone had similar symptoms, which turned out to be caused by a turbocharger that was incorrectly assembled.
Translated on 06-10-2026, 14:03.
Post28-03-2008, 11:44    Subject: Boost Pressure, VTG, Check Valve: I Don't Get It Quote
Is it conceivable that a detached VTG impeller could generate enough boost pressure to allow the turbocharger to operate without regulation, but that the pressure would be excessively high if the other impeller blades were also engaged?
There appears to be enough space in the turbocharger for a control arm to disengage.
http://www.technologie-entwicklung.de/07-VTG-Ring_sauber.jpg
Translated on 06-10-2026, 14:04.
Simusas
Post28-03-2008, 12:13    Subject: Boost Pressure, VTG, Check Valve: I Don't Get It Quote
Yes, that's certainly possible. As I said, I found a similar post. I'll link to it later (I have it at home).
It seems that the adjustment ring was installed incorrectly, which caused it to lock up. Unfortunately, I don't have a lift or a garage, which makes removing the turbo quite complicated.
However, I've been looking for a used turbocharger for a while now.
The turbocharger is currently in a maintained condition, which is something you generally wouldn't expect.
Here's the link: /viewtopic.php?t=4969&postdays=0&postorder=asc&highlight=rückschlagventil&start=24
Unfortunately, the images and logs are no longer available. It would certainly be helpful to have them.
Sven.
Translated on 06-10-2026, 14:05.
Andreas H.
Post02-04-2008, 19:43    Subject: Boost Pressure, VTG, Check Valve: I Don't Get It Quote
Yes, there were actually some ATL models with the shovel arms attached from the factory. Some were delivered that way, but it's a rare occurrence and falls within the PPM (parts per million) range.
This error can only occur during assembly. Once the impeller is correctly installed, the impeller blades will no longer come out of the pockets of the adjustment ring. If your engine was running properly before, it's unlikely that an impeller blade that was incorrectly installed from the beginning will now cause problems.
Why can the maintenance technician do it better? After all, they're just people too.
Greetings.
Andreas.
Volvo V70 II
Modelljahr 2001
2,5l 5Zyl. D5252T, 103kW,
ähnlich Motor AEL Audi A6 C4
Stand 04/08 245 000 km
Audi 80 B4 tdi 90PS 1Z
Modelljahr 1993
Stand 04/08 276 000 km
Translated on 06-10-2026, 14:07.
This topic is locked, you cannot edit or reply. Pa 3C BMR Won't Start: Error Code 004160 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts BLS - Erratic idle when AC is on - and more Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Power Loss: Air Mass/Boost/Timing OK? Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Boost Pressure: Does 20% More Mean 20% More RPM? Diesel Engine Technology
No new posts Check Valve for Radiator - Diesel Heater Part Diesel Engine Technology
No new posts Boost Pressure: Vacuum Leaks in Charge Air Hose? Diesel Engine Technology
No new posts G3 AFN: No Boost Pressure After Inspection Diesel Engine Technology
