Neue Ursache Ruckeln! | Posts 16+
Go to page: Previous  1, 2
joergs
Post11-03-2003, 13:02    Subject: Quote
The problem is the throttle position sensor (TPS). By adjusting the ESP slightly (see Ulf's DIY solution in the error database), I was able to eliminate the unstable idle and jerking at 1200 rpm.
Sure, I was able to remove it through adaptation on my original control unit as well.
However, there are also enough cases where adaptation doesn't solve the problem or where people don't trust the ESP (Electronic Stability Program).
Gesture recognition is a topic all its own.
I tried it out. Without the shock absorbers, riding in stop-and-go traffic feels like being on a goat, so that's not the solution.
Translated on 11-07-2026, 20:14.
Post11-03-2003, 14:27    Subject: Quote
joergs wrote:
Those affected have always written the same thing. The "10ct tuning" has little to no effect on the jerky 1Z engine (I experienced this myself - only an Authal box worked!).
My device always worked perfectly fine, even when there was some stuttering or lag.
The Authal box uses a series resistor with the reference coil. Some other boxes use a parallel resistor connected to pins 2 and 3, and those didn't work for me.
Other posts in this forum with similar issues of jerky 1Z engines and 10ct tuning also state the same thing.
Translated on 11-07-2026, 20:16.
joergs
Post11-03-2003, 14:31    Subject: Quote
Translated on 11-07-2026, 20:17.
Post11-03-2003, 14:41    Subject: Quote
joergs wrote:
Exceptions prove the rule icon_biggrin.gif.
No new posts Air Bubbles: Find the Root Cause & Fix It! Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document, 2.5 l, 6-cylinder / Jerking/Hesitation Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku V6 TDI AKE/AYM - Jerking and Lack of Power Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Gentle Vibration 1Z: New Idea Diesel Engine Technology
No new posts AMF Soot: LMM Cause? (Logs Included) Diesel Engine Technology
No new posts Engine Failure Causes: What You Need to Know Diesel Engine Technology
No new posts White/Gray Smoke: Causes and Solutions Diesel Engine Technology
