If the belt is already so damaged that it causes the gear to slip.
The camshaft signal is incorrect in relation to the crankshaft signal, which means the camshaft sensor is not producing a signal because it's outside of its operating range.
You're not the first one this has happened to!
B.Eng (FH) u. KFZ Meister
