TomRS
07-12-2005, 20:29 Subject: EDS in Skoda Fabia RS |
Hello.
I own a Fabia RS that is equipped with ESP/EDS (it was...).
(ordered as an option). In addition, the car has ABS/ASR - which is a feature that is...
The standard equipment of the car includes ABS, ASR, and ESP, which are all functioning correctly, but the EDS is not.
(differential lock) is not working - the brakes are engaging instead.
"The wheel is spinning uncontrollably. There are no error codes stored in the diagnostic system (VAG-COM)."
kommuniziert mit dem steuergerat ESP ohne probleme. Perhaps it lies...
das problem am falschen codierung ? It looks like that.
Address 03: ABS Brakes
Protocol: KWP2000
Controller: 6Q0 907 379 T
Component: ESP 8.0 front H03 0002
Coding: 0000296
Shop #: WSC 13765
Perhaps you can help me with this?
Greetings from Poland, and sorry for any typos.
Thomas.
Translated on 25-08-2026, 22:26.
matt Guest
06-02-2007, 23:24 Subject: EDS in Skoda Fabia RS |
I'm experiencing the exact same problem with my vehicle. The EDS (Electronic Differential Lock) is not engaging to prevent the spinning wheel. There are no error codes stored.
ABS, ASR engine intervention, and ESP are functioning.
How can I diagnose the problem more precisely?
Best regards, Matthias.
Translated on 25-08-2026, 22:28.
Mc_Givertechnik Schrauber
Joined: 02/27/2003 Posts: 390 Karma: +3 / -0 Location: Graz Österreich 2010 Volkswagen T5 Premium Support
20-03-2008, 9:32 Subject: EDS in Skoda Fabia RS |
I'm experiencing the exact same problem with my T4 2.5 TDI, which also comes standard with ABS/EDS. Yesterday, while driving on a grassy area, I noticed that the spinning wheel wasn't being braked.
Peter. VW T5 GP Multivan Startline CAAC 2,0 CRD 103 KW, Audi A2 1,4 16V AUA 2001, Audi A2 1,4 16V AUA 2003;Renault Zoe PHII 135 2020;
Translated on 25-08-2026, 22:29.
Profile PM Email Garage |
Benni Blaumann
Joined: 11/19/2005 Posts: 302 Karma: +15 / -0 Location: Braunschweig
20-03-2008, 19:17 Subject: EDS in Skoda Fabia RS |
The Electronic Stability System (EDS) only operates up to approximately 30 km/h.
However, with ESP activated, it would always be running, as the ESP system would be constantly intervening. Audi A5 B8 Cabrio 2.0 TFSI/CNCD 225PS
21-03-2008, 11:38 Subject: EDS in Skoda Fabia RS |
I've tried everything with my T4. I've tried gentle acceleration, aggressive acceleration, but only one wheel spins, with no reaction from the EDS (Electronic Differential Lock). I've tried the entire range, from idle to 3500 RPM. I then read the error memory, but there were no errors.
I would actually rule out overheating, as I drove for a short distance between attempts and even parked for a few minutes. The ABS functions normally, as does the cruise control (due to the pedal switches).
Where else could I try, and where should I start my search? All the wheel speed sensors must also be compatible, otherwise I would have an error message and the ABS system would indicate a problem.
Difficult, difficult...
Translated on 25-08-2026, 22:30.
Benni Blaumann
21-03-2008, 12:35 Subject: EDS in Skoda Fabia RS |
Does the T4 have an ASR or ESP switch?
To my knowledge, EDS (Electronic Stability Program) is only included with ASR (Anti-Slip Regulation) and is deactivated via the ASR/ESP button.
In addition, if there is a more significant intervention or control, the indicator light should blink. Audi A5 B8 Cabrio 2.0 TFSI/CNCD 225PS
Translated on 25-08-2026, 22:31.
21-03-2008, 12:44 Subject: EDS in Skoda Fabia RS |
That's not entirely correct...
My T4 doesn't have ESP. Apparently, ESP was also sometimes offered with ASR.
My 2000 T4 only has ABS/EDS.
There's also no warning light or switch for the ABS/EDS system. I've often wished there was a warning light, as I'd like to see when the system activates, but unfortunately, the T4 doesn't have one.
Regards, Peter. VW T5 GP Multivan Startline CAAC 2,0 CRD 103 KW, Audi A2 1,4 16V AUA 2001, Audi A2 1,4 16V AUA 2003;Renault Zoe PHII 135 2020;
Translated on 25-08-2026, 22:32.
Benni Blaumann
21-03-2008, 19:41 Subject: EDS in Skoda Fabia RS |
Okay, so this isn't based on knowledge, but rather a guess...
I think you'll still only find ABS in buses.
Because, if necessary, the EDS (Electronic Stability Program) should be able to be deactivated, and this is done via the ASR/ESP button.
I've only experienced it in the Fabia and Passat, and it seems like there needs to be a significant amount of wheel slip before the brakes are applied. Audi A5 B8 Cabrio 2.0 TFSI/CNCD 225PS
Translated on 25-08-2026, 22:33.
Maxx1278 Blaumann
![Avatar-Maxx1278]()
Joined: 03/02/2006 Posts: 233 Karma: +1 / -0 Location: St.Johann/Pg.
21-03-2008, 20:18 Subject: EDS in Skoda Fabia RS |
I can report that in the Golf 4 and Golf 5, even when the ESP is turned off, the EDS still functions.
SGM
Translated on 25-08-2026, 22:34.
matt Guest
17-05-2008, 15:44 Subject: EDS in Skoda Fabia RS |
In addition, if there is a more significant and frequent intervention, the control light should blink.
No, the EDS (Electronic Differential System) is always active, meaning it constantly compares the left and right sides with brake intervention. The ASR (Anti-Slip Regulation) button deactivates the throttle control, which is the reduction of power when the wheels are spinning. In this case, the comparison is made with the non-drive wheels.
Matthias.
Translated on 25-08-2026, 22:35.
