Hello bindpe?
If you have the necessary tools, it takes about 1.5 hours.
We need to take a look and see if the solution with the shorter strap will work.
I've done this before on a T4 with a gasoline engine, and also on a Toyota.
You can determine the belt length using a string. Measure the distance between the fully relaxed and fully tensioned belt tensioner, and then take approximately the midpoint of that distance.
When I look at the belt drive diagrams from AHU, both with and without air conditioning, I fear that the pulleys may not be 1:1 compatible
Take a look at it yourself
Best regards, Kurt.
