AFN ESP Leak: Troubleshooting & Repair Guide
dokatoto
Post24-05-2008, 20:54    Subject: AFN ESP Leak: Troubleshooting & Repair Guide Quote
I replaced the seal between the fuel filter housing (MSW) and the pump housing on my car, as there was a significant leak coming from the engine side. I bought a Bosch gasket set, followed the instructions carefully, started the engine, and it's leaking almost exactly the same way as before!
Okay, so I removed the MSW (manifold swirl valve), checked the gasket, cleaned everything thoroughly, paid close attention to ensure nothing was misaligned during reassembly, and put it back on. It was sealed then, but now, after 200 km, it's leaking exactly like before.
What did I do wrong? Has anyone else experienced this before? Are there different types of seals/gaskets?
Thank you and best regards.
Toto.
Translated on 19-08-2026, 3:58.
No new posts DPF not regenerating Troubleshooting & Guides
No new posts 2.7l V6 CR-TDI, Anpassungskanäle funktionieren nicht Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Not LLM: Poor Performance Explained. Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts TDI Not Starting? White Smoke - Get Help Now! On-Board Diagnostics (OBD)
No new posts agr dicht und/oder schlauch dicht; leistungsunterschied! Diesel Engine Technology
No new posts VP37 (ALH): Get Help & Solutions Now! Diesel Engine Technology
No new posts Need urgent help... Loss of power... Diesel Engine Technology
