Exhaust system broken - on the bracket behind the catalytic converter.
MKB: ABL, ACV
Cause:
In vehicles primarily used for short trips, the weld seam of the catalytic converter's suspension bracket can crack due to frequent and significant load changes. This can cause the catalytic converter's outlet pipe to break from its bracket.
Solution:
Install the catalytic converter using the double clamp.
"The following parts are to be used:"
1.9 liters / 50 kW
Catalytic converter (diameter 4.66" x 3"). Part number: 028 131 089 EX.
2.5 liters / 75 kW
Catalytic converter (diameter 5.66" x 6"), part number 074 131 701 FX. Tschüss
Michael II
Translated on 15-10-2026, 10:32.
