T4 TDI Speed Sensor Wiring Diagram ACV G22
homeonearth
Post02-06-2008, 17:03    Subject: T4 TDI Speed Sensor Wiring Diagram ACV G22 Quote
Hello everyone, I recently bought a DRK T4 van, and it had a tachograph installed. The sensor for the tachograph had 4 wires, but I replaced it with the standard sensor G22, which only has 3 connections.
My question is, 'How is this connected when the connector is oriented with the rectangular coding facing downwards?'
Year of construction: 2003.
Translated on 17-09-2026, 8:53.
UdoZ
Post16-06-2008, 22:07    Subject: T4 TDI Speed Sensor Wiring Diagram ACV G22 Quote
There should be at least one number visible there!
The signal is definitely located in the center, while mass and a Kl.15 connector are found on the outside.
-> http://www.t4-wiki.de/wiki/G22
Translated on 17-09-2026, 8:54.
No new posts Zero-tolerance for deviations in the steering angle of th... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Zero offset for accelerator pedal angle sensor (G85) in B... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Gear Ratio 6-Speed AAT/AEL Diesel Engine Technology
No new posts Oxygen Sensor Fault? Boost Pressure & No Idea Diesel Engine Technology
No new posts What kind of donor is this? Diesel Engine Technology
No new posts MAP sensor G71 Diesel Engine Technology
