VCDS 805: Fewer XPL Files for Faster Performance
Post22-06-2008, 12:30    Subject: VCDS 805: Fewer XPL Files for Faster Performance Quote
Hi.
VCDS 805 apparently has fewer XPLs than older versions. Since the format for LCode has also changed, the old ones cannot be used.
Will they be available again, or do we have to modify the old ones ourselves?
It was detected with a 46-3C0-959-433 (my Comfort Control unit).
While it does accept the 1K STG file, it contains less information.
Thank you.
Martin.
Translated on 04-08-2026, 19:22.
Uwe@Ross-Tech
Post22-06-2008, 15:07    Subject: VCDS 805: Fewer XPL Files for Faster Performance Quote
Fewer XPL files are indeed true, but it shouldn't be a problem because the data that is now missing from those XPL files has been moved to the LBL files.
In your case, the LCode information should now be in the file 3C0-959-433-46.LBL. If you are performing the coding while connected to KomfortSG, LCode should automatically load the correct data. However, if you attempt to modify the coding 'offline,' you will need to provide the correct file to the LCode program.
Furthermore, some data for your ComfortSG (particularly bytes 0-3) was incorrect in older versions, and we have removed it.
-Uwe-
Translated on 04-08-2026, 19:24.
Post22-06-2008, 17:10    Subject: VCDS 805: Fewer XPL Files for Faster Performance Quote
Okay.
"Thank you."
It would be interesting if LCode revealed where it's getting the data from. For example, simply displaying the filename in a small status bar.
... if you ever happen to have nothing to do icon_wink.gif ...
Translated on 04-08-2026, 19:25.
No new posts VCDS: Resetting DSG Transmission Settings Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Brake Bleeding with VCDS: A Complete Guide Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Battery Status with VCDS Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Label-Files for VAG-COM / FB to ZV On-Board Diagnostics (OBD)
No new posts A 150 hp TDI, less... Diesel Engine Technology
No new posts Tuning Box: Save 1L Fuel Per Trip Diesel Engine Technology
No new posts ARL Engine: Reduced Power Below 3000 RPM On-Board Diagnostics (OBD)
